How to use Fuelly with Prius Prime?
Discussion in 'Gen 5 Prius Main Forum' started by tovli, Oct 29, 2023.
  1. tovli
    tovli 2023 Prius Prime replaced 09 Prius
    346
    268
    Boynton Beach, FL
    2023 Prius Prime
    XSE
    How are folks with 2023 Prius Prime using Fuelly to get accurate MPG?
    I keep detailed “day data” and separate EV mode days from HV mode days. I try to have 0% EV capacity on HV days, because it seems like HV mode will use 7- 10% of EV mode SOC if it exists, giving a slightly inflated MPG.
    Using 10% of EV mode capacity means the Miles is about 5 miles higher than would be if there were no EV capacity. My average “HV day miles” is 55, so using EV capacity would likely inflate my “MPG” by about 5MPG, no?
  2. Trollbait
    12,233
    Fuelly simply isn't set up to handle dual or bi fuel vehicles.
  3. hill
    8,560
    You'd have to estimate electric use represented by 30mi/kWh (allows for losses / charging & discharging) then factor that into your fuelly data. It's about the best you can do.
    tovli likes this.
  4. tovli
    346
    268
    Boynton Beach, FL
    2023 Prius Prime
    XSE
    Good thought, but want to hear from some of these 12 people how exactly they are entering data into Fuelly.
    @HacksawMark ?jbpnoman @Toymeister ?idnwid ?nkris ?darkblitz ?rhallmcp ?LevieuxBook ?tekfuel @Chimera1978
    and @exbauer (two Prime XSE?)
  5. Salamander_King
    Salamander_King Senior Member
    11,001
    8,923
    New England
    They are all entering gal gas used for distance driven, just like any ICE car. Ignoring EV portion driven from the wall charge. By definition, that is an accurate mpg.That's why the MPG displaying on PHEV is totally meaningless.
  6. hill
    8,560
    note how more or less driving on gas or straight ev makes a lot of difference in overall economy .... some will be mostly gas while others just ev. Our Volt at 70K miles (for instance) has run ~90% of the time on electrons. Yet it's had over 6K miles of high speed cross country runs - besides driving over its (epa) 54 ev miles on rare occasions. That's resulted in a lifetime overall average of almost 80mpg .... even tho its gas only gets ~42mpg epa.
    Maybe some day fuelly will be able to account for varrying fuels.
  7. Blackat
    Blackat Active Member
    387
    244
    Colorado
    2023 Prius
    Limited AWD-e
    What does it actually do for you? Help you change your driving habits?
    I don't use it. I just drive as economically as I can in different situations.
    But, I'm not a data freak or into spreadsheets or pie charts so there's that.
  8. Salamander_King
    11,001
    8,923
    New England
    They may. But for a PHEV, unless the owner keeps a record of the kWh electricity used from the wall to charge the battery and distinguishes the miles driven by gas vs miles driven by wall charge, it is not possible to report accurate MPG for the gas portion. Gen4PP did not have the ability to record kWh used from the wall, nor did it display the actual miles driven strictly on the wall charge. I suspect Gen5PP is similar to Gen4PP in that regard.
    My current Escape PHEV reports kWh used from the wall for each charge session but does not keep the record anywhere. If I do not check the app and write down the amount of kWh on a spreadsheet, the data is lost. I double-check the app value against the actual kWh from the wall using a watt meter. It seems the App value is the actual kWh charged into the traction battery as they are always ~7% lower than the actual kWh drawn from the wall. Escape PHEV is just like PPs in that it does not report the miles driven on EV from the wall charge. So, there is no way to accurately calculate the MPG on the gas-only portion of the distance driven.
  9. tovli
    346
    268
    Boynton Beach, FL
    2023 Prius Prime
    XSE
    Off topic, but since it's my topic: Is that Level 2 charging?
    (I get 28% to 34% loss charging my 2023 Prius Prime Level 1 charger at 1.44kW per hour rate.)
  10. hill
    8,560
    i've never seen a 240v kWh meter other than the expensive / separate kWh meter some utility companies allow to be installed - to deliberately separate out car charge use. Even those don't calc' for ac/dc conversion losses .
  11. Salamander_King
    11,001
    8,923
    New England
    Using 120v L1 EVSE supplied by Ford. The difference between the watt-meter measures at the wall and the kWh charge at the traction battery reported by FordApp has been an average of 6.42% with a range of 3.66%-11.48%. I have used L2 EVSE at work to charge, but since it is not a commercial charger, it does not report the kWh used for the charge session. So, I don't know how much better the conversion efficiency is compared to L1 EVSE. In any case, your "28% to 34% loss" is crazily high. There has to be something off.
    tovli likes this.
  12. HacksawMark
    HacksawMark Active Member
    449
    317
    Oregon
    2023 Prius Prime
    XSE
    I'm confused by your question on using Fuelly for tracking mpg. Are you really asking about mpge?
    I simply enter miles driven, gallons used to fill up and cost per gallon. To calculate total cost per mile, I use total $ spent on fuel plus the estimated cost of electricity (.06 per kWh) divided by miles driven over a longer period of time, like a month.I use a watt wall meter to more accurately track the electric used to charge the battery.
    tovli likes this.
  13. tovli
    346
    268
    Boynton Beach, FL
    2023 Prius Prime
    XSE
    So that 73 MPG in your sig now, is “all miles EV and HV” divided by only actual gallons?
  14. HacksawMark
    449
    317
    Oregon
    2023 Prius Prime
    XSE
    Yes.
    tovli likes this.
  15. HacksawMark
    449
    317
    Oregon
    2023 Prius Prime
    XSE
    Okay so from what I've read, the energy contained in 1 gallon of gas equals 33.7 kWh. So when calculating what your "actual" mpg is, you can add the amount of equivalent "electric" gallons (based on actual kWh used to charge the battery) to the total actual gallons used to get a more accurate picture of total mpg.
    tovli likes this.
  16. Chimera1978
    Chimera1978 Junior Member
    San Diego
    2023 Prius Prime
    XSE
    I still use it out of habit more than anything. I still track my other cars in it. For my Prime, I'm not expecting anything super accurate for efficiency. I still like to see the trend of gas prices and tracking mileage.
    tovli likes this.
  17. exbauer
    exbauer Active Member
    1,185
    101
    Washington
    Like some have said. I just use the amount of gas I put in and divide by the number of miles driven. That includes my EV miles. I only have one Prius Prime. The other one I passed on to a relative. So, I don't track the miles anymore on that one.
  18. hill
    8,560
    you mean - like it was suggested in post #3 ??
    yea - that IS why the MPGe notion arose . Some plugins multi-function screens will actually divvy up the figures & then combine the result for you
  19. Trollbait
    12,233
    That is what the mpge figure is.
  20. Mendel Leisk
    40,233
    To answer the title question: just never plug in.
