http://www.blinglights.org/
Discussion in 'Gen 2 Prius Technical Discussion' started by Rockin Prius, Apr 27, 2010.
  1. Rockin Prius
    Rockin Prius New Member
    61
    NYS
    I am considering using this companies Fog Lights to "add" to our 2008 Prius which currently has "none".
    Does anyone have experince with them and can give an opinion in regards to quality?
    The ones I am looking at are under 2008 Prius Fog Lights.
    Thanks
  2. jelloslug
    jelloslug It buffed right out!
    813
    Greenville, SC
    Those are just generic lights. They won't use the stock mounts.
  3. Rockin Prius
    61
    NYS
    Thank You...
    Is there an aftermarket company that makes ones that will fit the stock mounts?
  4. kenmce
    kenmce High Voltage Member
    1,544
    515
    NY
    FYI, the stock fogs are useless for driving by. They are either decorative, or have some slight use as DRLs.
  5. jelloslug
    813
    Greenville, SC
    The Prius fog lights are used on a few other Toyotas, MR2 Spyders come to mind. I think just about any Toyota from the early '00s with round fog lights would be the same.
