HV Battery care " parking in the red
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by notch, Jun 3, 2008.
  1. notch
    notch New Member
    Pomona
    I have a battery cycle method that I use on my commute that I would like to share with the forum. I cycle the battery once a week.
    Morning 2 RED BAR START
    On the way to work I use a charging drive technique
    a mixture of coasting, light brakes and of course engine braking on off-ramps with a light pedal pressure on the brake pedal and I can reach a full peak charge 89% by the time I pull into work. I also prefer to have the rear window have-way down on either side to create drawing air to maximize cooling - I am certain the battery is getting warm (it just got a full charge
    Afternoon commute 8 full bars
    With the car fully charged driving on heavy traffic I am able to use liberal throttle and remain in ev mode to speeds up to 38 at speed I use the typical pulse and glide going warp steal with a variation of speed between 73-67 mph (less people will hate you and milage will average 55.5)
    Once off the free way the car will be somewhere around 4 blue bars- drive normal with the A/C at max cold last few blocks milk electric mode and you will reach 3 bars- Pull up into the drive way placing the car in nuetral and apply the parking break at you gather your things (a/c still blasting) turn off prius at two bars...
    The point is a consistent charge and discharge cycle will provide your battery with the longest life and when you use this method the battery stays in the green much longer... I cycle my HV batt once a week to insure it visits both ends of the batteries reachable volts
    After all that I have learned from this site I thought I would share this with you guys
  2. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    What sort of fuel economy do you typically get on these trips with your battery management strategy?
  3. prius12306
    prius12306 2018 prime advanced - Stella
    116
    rotterdam ny
    2018 Prius Prime
  4. prius12306
    116
    rotterdam ny
    2018 Prius Prime
    hmmm, never thought of that
  5. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    I was under the impression that keeping the NiMH battery within a narrowly confined operating limit helped prolong its life
  6. dogfriend
    7,512
    1,188
    Carmichael, CA
    +1. The car is programmed to keep HV Battery charge at about 60% on average.
  7. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    My Prius came with an ECU that takes care of the HV battery for me.
    I don't have to worry about such things as full peak charge, the typical pulse and glide, going warp steal, rolling windows up and down or cycling my battery.
    I can just enjoy driving this great car.
  8. rsforkner
    rsforkner Member
    369
    Boynton Beach, FL, USA
    2014 Prius v wagon
    NiMH batteries don't have a "memory" like the old mercury batteries. Deep cycles can actually be harmful. That's why the Prius works so hard to keep it between 40% and 80%. I paid good money to have the car worry about the battery.
  9. richard schumacher
    7,664
    1,042
    United States
    Everybody needs a hobby :_>
  10. ZC1
    ZC1 Junior Prius Owner
    711
    Metro Detroit
    Somebody needs a life, you mean.
    :ninja:
    ZC1
  11. notch
    notch New Member
    Pomona
    Almost anyone who uses rechargeable batteries has heard of the memory effect problem.
    For those who have not heard of this problem it is commonly believed that when rechargeable batteries are not fully discharged between charge cycles that they remember the shortened cycle and are thus reduced in capacity (length of use per charge).
    This problem was very common with rechargeable batteries up until about 5 years ago. With improvements in batteries and charging technology this 'memory effect' is becoming a thing of the past.
    Little known facts:
    * 'Memory Effect' is the common term used to replace the more accurate term 'Voltage Depression.'
    * Voltage Depression is more a problem with incorrect charging than a battery problem.
    * Voltage Depression does not necessarily permanently damage a battery. It can most likely be corrected by fully charging and discharging the battery.
    * Voltage Depression ('Memory Effect') is often incorrectly used to explain low battery capacity that should be attributed to other problems, such as inadequate charging, overcharge, or exposure to high temperatures.
    * Voltage Depression can be affected by the discharge rate of a battery. Generally speaking, the depth of discharge will be less on discharges at the higher rates. This increases the capacity loss as less of the active material in the battery is cycled.
  12. dogfriend
    7,512
    1,188
    Carmichael, CA
    :hand:
  13. notch
    notch New Member
    Pomona
    You prove my point These are essentially "stick packs" used for r/c cars
    its a 6cell sub c cluster- if you ever raced r/c and used these packs you would know what I do. I am going to build my own pack out of these:
    Pro Competition 5300 SHO - Team Orion
  14. dogfriend
    7,512
    1,188
    Carmichael, CA
    How long do your R/C car batteries last? Can you get 150,000 miles out of a battery?
  15. notch
    notch New Member
    Pomona
    yep- these are the same exact cells- the prius uses 6 cell sub c clusters... is this one of those snoby forums- i thought I would just share some info sorry
  16. dogfriend
    7,512
    1,188
    Carmichael, CA
    Sorry that I came off snobby. I am also trying to share information. But to be blunt, I haven't read anything in the Toyota owners manuals or service manuals that indicates that I need to do anything regarding maintaining the HV Battery. The tech training manual describes how the Battery ECU and the HV ECU work together to try to keep the SOC as near 60% as possible.
    You seem to be suggesting that we should manipulate the charging/discharging in a way that wasn't programmed in by Toyota. They provide a 10 year /150,000 mile warranty for the battery in Calif emissions states. Do you think they (Toyota) do not understand how they should maintain the battery?
  17. JimboK
    2,817
    188
    49
    Chesterfield, VA
    Snobby, no. (Usually. ;)) Skepticism, yes. A healthy dose of it is inevitable when someone's very first post runs contrary to the incredible amount of collective knowledge and experience in these parts.
    So while you're sharing, please share your answer to my question. What is your fuel economy with your battery management strategy?
  18. Danny Hamilton
    Danny Hamilton Active Member
    926
    94
    Greater Chicagoland Area
    Not snobby, but we want to make sure that when people come to PriusChat, they don't get misleading information or bad advice.
    I may well be mistaken here, but I'm pretty sure that. . . .
    "Memory Effect" is a very specific situation that applies to NiCd batteries, although people have adopted the term to refer to any situation where a battery appears to hold less charge than expected.
    In NiCd batteries Memory Effect was a situation where a battery is repeatedly discharged to an identical state before recharging. The battery apparently develops a short duration voltage drop at this discharge state which can be a problem for some electronic devices. While this sounds like what you are doing with your "cycling" of the battery, and as such would seem to indicate that you are going to induce a "memory effect" into your battery, it is important to remember that the Prius uses NiMH, and not NiCd.
    It is also important to note that NiCd batteries tolerate deep discharge better than many other rechargable battries.
    As for the more general use of the term, some of the potential causes of reduced battery capacity are:
    Dendritic shorting, in NiCd batteries, is caused by leaving a battery unused for an extended period of time. Thin conductive crystals can form which penetrate the membrane between the electrodes and create internal shorts.
    Voltage Depression - Caused by repeated over-charging, which causes the formation of small crystals of electrolyte on the plates. This increases internal resistance and reduces the voltage of some of the cells in the battery.
    Deep Discharge can cause individual cells to reverse charge if they are reduced to zero charge before the rest of the pack. This will reduce the output of the pack as a whole.
    Fortunately, since the Prius uses NiMH, it won't suffer dendritic shorting. Since it charges and discharges to different levels all the time as you are driving, actual memory effect isn't a concern. Furthermore, the vehicle protects itself from well-meaning attempts such as yours so that it won't experience repeated over-charging (voltage depression) or deep discharge. It does this by forcing the vehicle to begin recharging itself when it reaches about 40% of a full charge (and dispaying this 40% state on the "Energy" screen as an empty battery), and by cutting off all charging of the battery when it reaches about 80% of a full charge (and displaying this 80% state on the "Energy" screen as a full battery).
    So first, you are never really fully discharging nor fully charging the battery with your process. Second, you are attempting to protect your battery from effects it will not experience. Third, the battery management system is protecting itself from you. Fourth, all that heat that you are generating in the battery, by charging and discharging it as much as the vehicle will let you, is energy that could have been put to better use pushing the car down the road. As such the vehicle will need to generate more energy for the purpose of moving itself than it otherwise would have. In other words, you aren't really gaining much, but you are reducing you MPG for each tank of gasoline you use.
  19. ken1784
    ken1784 SuperMID designer
    2,943
    1,380
    67
    Yokohama, JAPAN
  20. bbald123
    bbald123 Thermodynamics Law Enforcement
    386
    272
    Harrisburg, PA
    It amuses me that people think they can get better results than multi-million dollar engineering projects. Then they expect the more technically minded among us to accept unverifiable hearsay or anecdotal evidence over the results gleaned by trained and experienced scientists and engineers.
    I choose to believe those who are rigorous in their approach. I, by default, accept well known principles of science and engineering until VERIFIABLE evidence to the contrary is presented.
    In the context of this discussion, I'll believe what Toyota says is best for the HV battery. They have a significant risk in failure because they have to replace batteries that fail before 150,000 miles. They have an even larger risk because if batteries fail en masse their customer base will defect.
