Hybrid battery pack. What is this telling me? Which cells are bad or is the whole thing bad.
Discussion in 'Gen 3 Prius Technical Discussion' started by IllyaPrius, Jun 25, 2022.
  1. IllyaPrius
    IllyaPrius New Member
    Can someone please explain what I’m looking at? Voltage for the pack seems a little high but I can’t tell which cells are bad. Thank you!
  2. IllyaPrius
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,135
    Tampa, FL
    Pack voltage is fine. Blocks 7 & 8 are starting to show their age, though. Grid charging with a Prolong or Maxx Volts might bring them back into line. Just replacing one or two blocks is called "whack-a-mole" since you'll be doing it again and again. The best solution is a new battery or a new set of cells from someone like @2k1Toaster if they have them in stock.
    IllyaPrius likes this.
  4. IllyaPrius
    I would like to mention that my Prius turns to engine only when it’s really hot 80+ F. It’s fine in the winter though. Any idea if this is because of the cells? I get the PA080 code when this problem occurs.
  5. jerrymildred
    11,517
    14,135
    Tampa, FL
    P0A80 indicates a failure of at least one of the cells in one of the blocks in your battery. If the code reader includes descriptions, it will say, "Replace hybrid battery pack." There will be another code that tells you which block or blocks has/have "become weak."
    Sorry for the grim news, but it's time for a new battery. You might be able to drive it for a while by resetting the codes, but at some point in the near future you will be sitting by the side of the road (maybe in bad weather and/or an unsafe location) wishing you'd replaced the battery sooner.
    It is remotely possible that corrosion in the battery connections or sensor wires could cause this, but it's almost always one or more failed cells.
    Here's a pretty good explanation.
    P0A80-Replace Hybrid Battery | Hometown Hybrids
  6. ASRDogman
    ASRDogman Senior Member
    7,015
    3,670
    Have you clean the hybrid fan? And checked the filter to make sure it's not clogged?
    And make sure the fan is functioning?
