Hybrid battery voltage sensor J circuit low P0B6A
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jorge Torres, Apr 19, 2023.
  1. Jorge Torres
    Jorge Torres New Member
    Puerto Rico
    I have this problem and i dont know which sensor is that.
    Any help please
    Thanks
    50,863
    i would open up the battery and look for corrosion
  3. Tombukt2
    Tombukt2 Senior Member
    11,717
    2,076
    Durham NC
    I would imagine if you can get a hold of a download or a view of the factory manual it will place that sensor on a chart or you can see its placement in the battery case or like been said here before you can just open up the case and have a look for some nonsense corrosion You're going to see some on other things anyway You might as well start taking a look it would be a good idea and then you can figure out what all you need to address and it will be more than just this one sensor especially once you have it all apart.
