Hybrid Battery
Discussion in 'Gen 2 Prius Main Forum' started by lichristensen, Jun 20, 2009.
  1. lichristensen
    lichristensen New Member
    MidWest
    Hey everyone. I have a 2006 toyota Prius. I got it in November and love it. I'm glad that I got it for my first car. Tonight after working for 5 hours I went through a drive thru. Well I had to wait for about 10 min. to get the food and I keep the car on when I started driving away I notice that I was down the pink for the hybrid battery. Then when I keep on driving it was blue. Is this normal?? is my battery starting to die?? Please let me know. Thanks.
  2. Patrick Wong
    18,200
    6,490
    If you had the air conditioning on and the ambient temp is high, then the A/C compressor will consume considerable power from the traction battery. Once the traction battery SOC gauge drops down to two red (or pink) bars then the engine should start to charge up the battery. This is normal behavior.
  3. lichristensen
    MidWest
    Ok thank you. I did have the air on at like 69 and on defrost for the back and rear window. I was really worried about the battery glad to find out its normal and the engine did got on. Thanks again so much. Also how far should the battery go down when it sits at night?
  4. Bob64
    1,540
    93
    Virginia
    The traction battery typically doesn't drain much, if at all overnight. If it drops from full green bars to 1 bar purple, then you may have a problem (or you left the car on).
    For me, it appears to stay the same. Any decrease is usually unnoticeable.
  5. lichristensen
    MidWest
    Thank you. I think the most I notice is two bars. But when I start driving it the battery is back up. I think I'm just being over worried about the battery since this is my first car and I'm the only one in my family with a hybrid.
    I went on vacation and had my mom drive my car every other day or so and now she wants to get one. She has a chevy impala and has had nothing but problems with it and is getting like 27 mpg.
  6. lichristensen
    MidWest
    And when I said two bars it will lose two bars. Not it goes down to only 2 bars left.
  7. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    Dropping 2 bars overnight is not unusual. I've seen it as well and the car was definitely off all night. It seems to be a case of the ECU recalculating what the actual battery SOC is upon the new start. Others have reported the same effect as well.
  8. lichristensen
    MidWest
    Thanks for all the input. I think I was more freaked to see the battery with just two lines left. I thought there was something wrong with my battery when I was stoped getting my food.
  9. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    it goes down to 1 bar... at 1 bar it's really only down to 50 percent charge or so.. and when it's full with all green bars, it's only about 85 percent carged... so you're only useing 35% of the battery.
    if you have 1 purple bar, the engine will run untill it hits 2 bars or 3 bars.. then shut back off..
    if you have two bars, the engine will kick in when you let your foot off the brake... or may kick in ( depending upon accessories you have running) till hit hits 3...
    if the pack gets too high, it waste power by forcing you into EV mode...
    it's very very very self regulating.
    only worry if it never charges back up past 3 bars... ( for multiple days)
  10. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    To pull together the others' comments, the car manages the battery quite well on its own, babying it to prevent over-charging or excessive discharging. Some of us pay close attention to state of charge as we try to eke out the best fuel economy possible, but that's not necessary for those who choose to drive normally. Enjoy the ride and trust that the car is doing its job.
  11. Patrick Wong
    18,200
    6,490
    One way that the Prius driver can screw up is to shift to N (instead of P or leaving the car in D) when sitting in traffic or a drive-through line, etc. While the car is in N, the hybrid system cannot charge the traction battery.
    If you have the A/C compressor on then the traction battery will quickly discharge, perhaps beyond the point that the system can recover. So, avoid the use of N in normal driving.
    If you go through a car wash where you need to shift into N, I suggest you make sure the A/C is off.
  12. lichristensen
    MidWest
    I actually turn my car off in a car wash. Another question not with the battery but when I turn the AC on it turns into inside air only is that normal?
  13. Foulwx
    Foulwx New Member
    Eastern PA
    That leads me to a question...How do you set up the car when going through one of those car washes that pushes the car along a track and the wheels have to spin? Must you leave it ON and either in N or D?
    Thanks!
  14. lichristensen
    MidWest
    Well the car wash that you drive in and the stuff goes around it and the car doesn't move on the wheel things.
  15. Foulwx
    Foulwx New Member
    Eastern PA
    I wasn't sure whether the wheels spin or not - I haven't used one of those car washes in years.
    Another rainy day in PA...
  16. patsparks
    10,664
    567
    Adelaide South Australia
    If you press the power button from off twice then select neutral the wheels will be free to turn and the engine wont start. I would leave the AC off in this mode. At the other end, select park then with your foot on the brake press power button again, the car will go into ready mode.
    You can also select neutral while in ready mode but if the battery runs low it can't recharge.
  17. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    Personally, I've never been in a car wash that took so long that running the A/C drained the battery :p
  18. Blauer Glimmer
    Blauer Glimmer Active Member
    448
    169
    NY (Southern Tier)
    Mine defaults to recirculating air when I turn on the AC.
  19. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    Find something else to worry about. This is normal. 2 bars represents 40% charge. The car will keep the charge state between 40% and 80%. This maximizes battery life.
  20. Frayadjacent
    Frayadjacent Resident Conservative
    375
    Austin, TX
    The AC turning on recirculate is good, and should happen except when the outside air is cooler than the inside air.
    From right at just below the green bars, I was able to run my AC for about 25-30 minutes before it hit the first purple bar. Ambient temperature was over 90º, and the AC was set around 77º.
    The lower you set the temperature, the harder it works and the quicker it will eat your battery.
    If it's hot and sunny where you are, invest in a sun shade for your front window and a good tint job. The glass in the Prius (at least the sides and rear) are pretty good at rejecting heat, but some tint could help quite a bit. Leave a window cracked if you can, and park in shade if you can.
    When you start out on a hot day, roll down the windows to flush out the hot cabin air. Turn the AC on and set it to fresh air for a couple minutes. When the hot air in the cabin is flushed out and is about the same temperature as the outside air, roll up the windows and leave it on fresh for another minute or two, then turn on recirculate.
    It's also a good idea not to set the AC on full blast (down to a really low temperature) if you'll be comfortable with it at a higher temperature. The temperature setting just controls the speed of the fan, apparently. In 100º weather here, I can be perfectly comfortable in my car with the AC at 75º.
