Hybrid Light Info
Discussion in 'Gen 2 Prius Technical Discussion' started by Brad Hellickson, Sep 3, 2015.
  1. Brad Hellickson
    Brad Hellickson New Member
    Corona, CA
    Hello Everyone,
    Hoping to get some assistance here. I am getting the red triangle and the little car with exclimation point on the MFD. Interestingly all of the amber lights are on and the brake light is on BUT the parking brake is not set.
    Here is what happened --my hybrid battery died a few weeks ago so I ordered a replacement through Summit Racing (Dorman Battery). The car started and drove but I had to rest codes to keep it alive (just to get it home). Last moved it 3 weeks ago and removed the old battery.
    So long story short -- while I was waiting for the new battery I repaired some other issues -- BTW I am not new to this, I have the tools and have done these repairs on conventional cars many times.
    1. Leaking axle seals -- replaced L and R seals
    2. replaced L and R half axles (drivers side was rough so replaced both)
    3. Found drivers side wheel bearing to be rough so replaced L and R hubs
    4. Replaced L and R struts and strut mounts.
    5. Drained and refilled trans axle with Toyota W (TF) 4 qts
    6. Installed new 12v battery (currently producing 13.4v)
    7. Replaced rear struts.
    8. Replaced L and R front rotors and shoes -- they were off anyway so why not. No loss of fluid!
    9. Removed and cleaned most interior parts -- door panels, seats etc...
    Installed new HV battery and fired her up to the usual wheezing, whining and clicking sounds. But NO engine -- just the triangle -- problem statement and and the other above issues.
    Checked the following -- inverter pump is circulating nicely, though maybe battery electronics -- so I placed the old battery back in (it was started with the old one 3 weeks ago) -- nope same issue so not those electronics. Traced all wires, plugs and connectors related to hybrid system -- all seem to be in place.
    No codes appear on my code puller.
    It must be related to one of the repairs I did but I cannot imagine what I did incorrectly -- so any advice from a Prius tech with more experience would be VERY appreciated. I am at a loss with this one.
    I was hoping for some voodoo Prius magic like standing on your head while pushing the trip button and holding the window switch on the right passenger door down all within 3 seconds to reset the hybrid system but I can't seem to find anything!.
    Thank You!
  2. m.wynn
    m.wynn Senior Member
    684
    1,229
    Queensbury, NY
    Did you slide the service plug handle into place after latching it?
    Nice job on the maintenance, too.
    strawbrad likes this.
  3. Brad Hellickson
    Corona, CA
    OMG is it that easy! I did not do that. I am heading back to my garage now to give it a try. Then I am coming to NY to give you a big kiss!
    m.wynn likes this.
  4. strawbrad
    953
    1,002
    The first start after pulling the 12 volt battery requires two pushes on the power button. The first push will light the dash up light Christmas time. Keep your foot on the brake for both pushes.
    Brad
  5. okcwxguy
    okcwxguy Junior Member
    Oklahoma City, Oklahoma
    I forgot the plug when I replaced my Hybrid Battery as well. There's no feeling in the world like the relief you feel when that was the only problem. :)
    Fone ?
