Hybrid systems check
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Soonergal10, Jan 2, 2019.
  1. Soonergal10
    Soonergal10 New Member
    Oklahoma
    I have a 2010 Prius. I was driving this morning and my check engine light came on along with the triangle with an exclamation in the middle. It said check hybrid systems. The car still turns on. It started slowing down and wouldn’t accelerate. Once I stopped it completely it would no longer go. After sitting for about 10-15 minutes I turned it back on and it started going like nothing ever happened. Any idea what could be causing this?!
    51,932
    welcome!
    how many miles on her?
    could be anything, you'll need to get the trouble codes pulled for direction.
    sometimes a blown inverter pump will stop the car due to overheating safety shutdown, then let you start up again after the temp drops below threshold.
    any movement in the inverter fluid reservoir with the car in ready?
  3. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Sounds like the inverter water pump;).
    I’d look to source a new one. To do the job, I believe you have to loosen the inverter for access:cool:.
    I am preventatively replacing our 2010’s water pump once it arrives from Amazon. Due in later this week:).
    Good luck and keep us posted (y).
    m.wynn and Soonergal10 like this.
  4. JC91006
    16,768
    8,565
    Get nutzaboutbolts to do a video with you
    m.wynn and Raytheeagle like this.
  5. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    I’ve offered @NutzAboutBolts but they’ve shot me down :(.
    Maybe new year, new response (y).
    m.wynn and NutzAboutBolts like this.
  6. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,698
    1,745
    Bay Area
    No place to film, still renovating
  7. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    My “shop”:whistle:?
    It even has a refrigerator now for cold adult beverages (y).
    bisco, m.wynn and NutzAboutBolts like this.
  8. NutzAboutBolts
    1,698
    1,745
    Bay Area
    Hahah been a busy year. I’m suppose to finish filming the dashcam but been procrastinating... :(
    Raytheeagle likes this.
  9. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Let me know what works for you and I’ll see if I can accommodate(y).
  10. Soonergal10
    Oklahoma
    I have about 175,000 miles.
