Hypermilers may need to Initialize...
Discussion in 'Gen 3 Prius Main Forum' started by Blind Guy, Jun 14, 2009.
  1. Blind Guy
    Blind Guy New Member
    352
    194
    Springfield Missouri
    ATTENTION Hypermilers!:eek:
    I was reading (rather, listening to) the 2010 Owners Manual and I ran across an interesting statement.
    In the manual the TPMS section (Tire Pressure Monitoring System) talks about "initializing" that system whenever Tires are replaced, changed or the tire pressure is modified.
    During the "Initialization" process, you are to set the cold Tire Pressure to a given value, then "Initialize" the system. This lets the TPMS know the correct value for any given Tire Pressure, and at a given lower value, it will indicate "Low Tire Pressure". This "Initialization" tells the TPMS what the expected normal pressure is supposed to be.
    I was thinking, for you Hypermilers, since you typically hyper-inflate the tires, lets say on the 2010 17" tires, to 42 psi front and rear (standard is 33 psi front and 32 psi rear, if I'm not mistaken), and for this arguments sake, lets say the "Low Tire Pressure" warning value is triggered at 25 psi, if you had inflated those tires to 40 psi and are concerned about maintaining those pressures as close to the 40 psi as possible, without re-Initializing the tires at the higher value, you would NOT get a "Low Tire" warning warning until 25 psi, 15 psi BELOW your ideal tire pressure value (since the tires were originally "Initialized" at 33/32 psi), significantly altering any attempt to improve mileage with those higher pressures.
    So, if excellent mileage is important to you, and you keep your tires Hyper-Inflated, you may want to read pages 434 and 435 in your Owners Manual, so you can "Initialize" your tires at their higher value, so as to raise the trigger point for a "Low Tire Pressure" warning!
    David (aka Blind Guy)
  2. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Not a hypermiler, but I do pump up. I didn't have to reset TPMS in my car when I upped to 44/42 hot which yielded 40/38 cold (well, desert cold).
  3. bwilson4web
    15,934
    The tire pressure monitor is really more about avoiding a flat tire and the damage to the side walls ... or that is my impression. I'd inflated my tires to maximum side wall pressure, 44 psi, but a week later, the indicator came on. One tire had dropped to about 28 psi. Late, I added it back to 44 psi and the indicator went out. The next morning, I checked and the pressure was down to 38 psi. So I took it over to Firestone and they found a nail and repaired it.
    Understand, I'm an efficiency driver and anything over EPA mileage MPG is not good enough, it is perfect. But I also like the better traction, rain handling, and higher speed turns of tires at maximum sidewall.
    I've found most tires lose about 1.5 psi per month. So in about three months, I expect to find the tires under 40 psi.
  4. David Beale
    David Beale Senior Member
    5,963
    1,985
    Edmonton Alberta
    Nothing new here. Even the GII has an "initialization" button. I like to use it whenever I set the tire pressure, even if I don't change it, just return it to where I normally run.
  5. Gord
    Gord New Member
    55
    Glasgow, UK
    On all my vehicles tire pressure is checked every single morning along with inspection of the engine bay, fluid levels and to make sure there is no leakage and a quick underbody inspection is made before I set off ANYWHERE. So when I get my 2010 I doubt the TPMS would be of much concern to me.
    On the Driving Instruction vehicle an extensive check of everything is made in my parking lot before I leave. Don't want there to be something wrong that could put my pupils' life in danger, such as messed up brake lines or power steering faults.
    Since I learned to fly when I was 16, I have always done my "pre-flight" inspection. (and it drives people up the wall!)
  6. dogfriend
    7,512
    1,188
    Carmichael, CA
    Yes, I reset mine when I set the tires to 40f/38r.
    A good side effect of resetting it is that the warning indicator comes on when the pressure drops to approx 35 psi (the factory recommended pressure). When I bought a new set (2) tires at America's tire store, the TPMS light was on when I got the car back. I found that the tire shop had adjusted all 4 tires to the settings on the door sticker. I of course set them back.
  7. a priori
    a priori Canonus Curiosus
    3,083
    407
    23
    Chicagoland (West)
    Yes, I initialized the TPMS system after inflating my 17" tires to 42/41.
    Thanks for pointing this out!
  8. fuzzy1
    10,332
    Just a terminology adjustment ...
    I dislike the terms 'hyper-inflated' and 'over-inflated' for anything at or less than the maximum pressure listed on the sidewall. For all the tires on my various cars, this is also the minimum required pressure when operated at their full rated tire load.
    I prefer the term 'fully inflated'. This causes less alarm among the folks who believe it is a sin to inflate tires to pressures higher than suggested by the car's placard, even when conforming to the tire manufacturer's rating.
    2 people like this.
  9. MaggieMay
    MaggieMay Active Member
    534
    68
    Gloucester, MA
    This seems like a reasonable thread to ask the question: Why type of tire gauge do you guys use? The "old fashioned" stick kind or a digital gauge? Pros and cons? The gas station where I use the air machine has a guage built into the nozzle, but I've always been a little skeptical of its accuracy. Thanks!
  10. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    I've used an Accu-Gage for a long time:
    Dial Tire gauges
    Very accurate, easy to use (has a bleed valve which makes getting the desired pressure easy), and durable.
  11. HTMLSpinnr
    5,341
    920
    251
    Plain ol stick works okay - used to have a digital, but it's battery died and I haven't bothered to check into its replacement.
  12. timberwolf
    timberwolf New Member
    220
    31
    UK
  13. rrkessler
    rrkessler New Member
    Park City, UT
    So, this is a highly interesting thread. I've always kept my tires at manufacturer's levels as indicated on the door. I realize that keeping your tires inflated helps your gas mileage. But does super inflating them or max inflating them or whatever is the right term reduce the lifespan of the tires? Do you need to rotate more often or something? When we got our first Prius (Gen II), we didn't heed the 5K rotation on the first 5K and at 10K we had really worn the tires out. So, we are very religious about it now.
    Thanks.
    Bob.
  14. Blind Guy
    352
    194
    I use an Acutire talking tire gauge, Its speaks the tire pressure when it is pressed on the value stem.
    The nice thing is it is accurate to a half pound.
    David (aka) Blind Guy
  15. lauren80ryan
    lauren80ryan New Member
    165
    26
    Tri-Cities, WA
    Gord, I have to admit, I took private pilot lessons (a whole 6 hours:p worth) so I understand the importance of the pre-flight inspection; also, my grandpa and uncle were/are professional pilots and my dad has his PP license and flies about once/week. That being said, you would drive me crazy in the mornings!!!!:D LOL
    my husband yells at me for not checking the oil when I fill my gas. But because of him, i am VERY good about regular oil changes and maintenance.:)
  16. dogfriend
    7,512
    1,188
    Carmichael, CA
    I think that PriusChat consensus is that inflating the tires up to the max cold pressure on the sidewall will actually increase the lifespan of the tires. PCers who have followed the door sticker recommendations have complained about early tire wear with the edges of the tires wearing faster (typical underinflation wear pattern).
    I know that in my case, I still have two of the original tires on the front and I am almost at 30k miles. I rotated them every 5k for the first 15k miles, then found a nail puncture that could not be repaired so I bought a set of 2 and put the original tires on front for the next 15k (almost). I still have legal tread depth (and reasonably even) at inflation pressure between 40 - 42 psi.
  17. Philosophe
    Philosophe 2010 Prius owner
    437
    72
    Montréal, Québec (Canada)
    From what I've read elsewhere, modern radial tires keep their flat shape up to their maximum recommanded pressure, so lifespan is in no way diminished.
  18. CAR4TWO
    CAR4TWO New Member
    239
    Grants Pass, OR
    I totally agree with you Dogfriend. Being a by the numbers kind of guy, I followed the tire pressure levels in the door jam. I went through two sets of tires very quickly. I now carry 36 all the way around in the Suzuki and Mercedes SLK. The Corvette calls for 30 on all four corners and I run those Goodyear's at 31/32. I think Chevrolet got theirs right.
    What are you running on your Prius?
    Dan
  19. MaggieMay
    534
    68
    Gloucester, MA
    Talking tire qauge?? Awesome! I am always fumbling with my reading glasses to see the stick! Thanks David!
  20. dogfriend
    7,512
    1,188
    Carmichael, CA
    40 -42 psi front / 38 - 40 psi rear (the recommendation is for a 2 psi differential between front and rear on the 1st and 2nd gen Prius) Max cold inflation is 44 psi for the tires on my car.
