I don't get it.
Discussion in 'Gen 2 Prius Main Forum' started by cyberbro, Nov 13, 2007.
  1. cyberbro
    cyberbro Junior Member
    I don't get it.
    I have about 3,500 miles on my 2008 I have averaged the whole time from 46 to 47 MPG's
    The first few tank fill ups I got about 130 to 170 miles on the first pip, the last 3 tanks I have lost 3 pips at 120 miles. I seem to get about 375 to 450 mile per tank when before it was closer to 450 to 500 mile per tank. I'm still getting the sames MPG though. Any ideas, winter gas mix?
  2. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    <div class='quotetop'>QUOTE(cyberbro @ Nov 13 2007, 07:09 PM) [snapback]539225[/snapback]</div>
    You didn't mention how much fuel is going into the tank. Since the tank shrinks/expands due to temperature that is a major consideration. Types and blends of fuel matter as well but that will effect your MPG, the amount of fuel you pumped will not.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    If the MPG remains the same, then the difference is the bladder in the fuel tank or the pump you use to fill the tank. The capacity of the fuel tank in the U.S. version of the Prius can vary by several gallons depending on temperature, the pump used for filling, phase of the moon, and your astrological sign. Don't put too much thought into it, just be aware that it varies from fill to fill.
    Tom
  4. Bebopp
    Bebopp New Member
    <div class='quotetop'>QUOTE(qbee42 @ Nov 13 2007, 11:15 PM) [snapback]539252[/snapback]</div>
    According to Toyota, fuel bladder capacity varies by about 5 liters (or 1.3 gallons), NOT several gallons.
  5. qbee42
    18,058
    3,076
    Northern Michigan
    <div class='quotetop'>QUOTE(Bebopp @ Nov 14 2007, 02:26 PM) [snapback]539547[/snapback]</div>
    Okay, you got me. The gross capacity of the fuel tank is 11.9 US gallons, and most of us figure the usable capacity to be somewhat less than 10 gallons, unless you like to gamble. That makes for about two gallons. Perhaps saying "a few gallons" would be better.
    Tom
