I don't think I need this, do I????
Discussion in 'Gen 2 Prius Main Forum' started by canesfan, Sep 13, 2012.
  1. canesfan
    canesfan Culture shocked...
    544
    Jacksonville, NC
    Went to the dealer Monday for my 60,000 mile service. When all was said and done the guy said I needed a Fuel System Service. The guy told me that you can get carbon buildup on the fuel injectors, blah, blah, blah. I asked him if they had actually seen this while doing my service and he said yes. I told him I would take it under consideration, but couldn't do it at that time. After thinking about it for a while, I'm wondering about a few things...
    Would they actually look at/be able to see the fuel injectors while doing a regular 60,000 mile service to know I need this?
    As a part of every service I have done there, they always use a "fuel system cleaner" (about $6). Shouldn't/Wouldn't that help prevent whatever issue they think I have now?
    On the invoice it says this service is recommended every 15,000 miles. I'm thinking it's a bunch of baloney...
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    You are correct, the Fuel System Service is not needed and is just a dealer upsale. What most have reported on here that may be needed with a car with your mileage is a Throttle Body cleaning. You can get carbon buildup on the Throttle Body. This is a DIY task if you are so inclined. There are instructions on here on how to do this. If not you may want to ask the dealer, or your trusty mechanic, to perform the throttle body cleaning.
  3. canesfan
    544
    Jacksonville, NC
    This is what my invoice says the service entails:
    "This service cleans fuel injectors, throttle body, plenum, air-intake, intake valves and ports. Removes combustion chamber deposits, reduces emissions. Restores horsepower. Increases fuel economy."
    I'm assuming the throttle body cleaning you mention is different than what is mentioned?
  4. jdcollins5
    5,131
    1,342
    Wilmington, NC
    The throttle body cleaning is one of the many items listed in the service. Search on here for an article "What services you need and what you do not". It was written by a former Prius tech. Very good article to read and be familiar with in these circumstances.
    usnavystgc likes this.
  5. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    I'm inclined to clean the throttle body when my fuel economy takes a hit. Since Galaxee pointed out a down side this is a case of "if it ain't broke don't fix it."
