I really don't get it???
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by dorian10, Apr 25, 2011.
  1. dorian10
    dorian10 Junior Member
    irvine
    Could someone please explain the plug in Prius to me? Considering buy a "regular" Prius, just got an Email to be put on the List to get a Plug in.
    You plug the car in for 1.5- 3hrs then you get to drive 13mi ? I don't get it!
    How many Prius owners bought their car because they have a 13 mi commute?
    I'm sure I'm just missing something, can anybody help me out w/this?
    Thanks
    DC in the OC :confused:
  2. richard schumacher
    7,664
    1,042
    United States
    You get to drive 13 miles without using any gasoline. If you continue driving then the engine starts, and you just keep going. If your commute is 26 miles per day it's like getting more than 100 MPG. Depending on where you get your electricity this can be a significant further reduction in greenhouse gas emissions beyond that of a non-plug-in Prius.
  3. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    It doesn't have to be about the commute. One can use this for their regular "around town" shopping and errands. In my case, I commute 110miles a day but in the evenings and weekends I run around our small town multiple times throughout the day. In this situation I could use all EV miles and reduce my pollution footprint instead of driving a few miles at a time with a cold engine.
    At first I assumed the 13 miles (approx.) was useless because I focused on my commute but the more I thought about what drags my MPG down from my excellent freeway average, I realized it was the short trips I make to pick up food, car parts, Home Depot, etc.. During those short trips you might only average 35-40mpg. This drags my 53-57mpg freeway average down to high 40s or low 50s depending on how many trips I make.
    2 people like this.
  4. gwmort
    gwmort Active Member
    985
    211
    Delaware
    A "regular" Prius is incredibly efficient, and while it has both an electrical power system and an internal combustion power system all of the energy used by the car comes from gasoline.
    In a Plug-in Prius, the battery will be larger than a normal Prius and you'll be able to bring electrical power on board through a plug rather than generating your own electricity by burning gasoline.
    For the first 13 miles or so the primary source of your motive power will be the electricity that came into the car through the plug, assisted mildly by the ICE during heavy loads or when it is most efficient to do so. After that 13 miles it reverts to operation exactly like the normal prius to generate its own electricity and share propulsion more evenly between the electrical and ICE power systems.
    The idea is you get a boost from your local power company that helps reduce your need to use gasoline. Some people with very short commutes or who can charge at both ends of their commute will burn very little gasoline at all, but if you have a longer commute its not a problem as you'll still get operation as good as a normal prius plus the boost of burning substantially less gasoline during the first part of your trip for a much better overall fuel economy.
  5. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    And anyone who is familiar with the Pulse & Glide technique will know that a 13 mile "glide" would be awesome for your average MPG. :D
  6. dorian10
    irvine
    Thanks for your reply, but Thats the part I don't get. Why would I want to pay $10k more for a plug in and only get 13 mi range using no gas? If I I did my calculations right , I save aprox $35 a month on fuel vs a standard Prius.
    Prius gets 45 MPG , gas is $4 a gallon, 13mi divided by 45 is aprox 3.5. cost to drive 13mi a day is $1.14 for gas. I save 1.14 on gas x 30 days a month = $34.29 savings?
    Is my math wrong? I pay $10k more for a plug in to save $34 a month? I make up the difference in 25 yrs, Like I said I don't get it???:eek:
  7. gwmort
    985
    211
    Delaware
    Pricing hasn't been announced, some people here think it will only be an additional $3000 or so. Part of the benefit depends on how much you can charge, if you charge at work you get double the benefit of charging only overnight, or if you come home and plug in for a little bit before heading off to dinner or something.
    Also gas prices have more than doubled during the lifetime of my last car, think about your payback period at $8 gallon gas.
  8. krelborne
    krelborne New Member
    295
    Alabama
    Where did you get the idea that the plugin would be $10k more?
  9. bisco
    50,800
    we don't know the price yet, but it likely won't pay for itself on fuel savings. the point is to slowly move toward alternative/renewable energy sources so that someday, we won't be dependent on oil and also can reduce pollution.
    as for you, if you can find a prius now, i would buy it. the plug in won't be generally available for a good two years or more. all the best!
  10. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    As stated, the price has not been announced and even once it is announced you can factor in the state and/or federal rebate for it being a plug-in car.
    That being said, I don't think the car is set up to be so economically viable that you will pay off the "premium" for the plug-in in a very short period of time unless you have a very short commute like I used to (13miles to be exact). Also keep in mind that the first 10miles or so of a commute is done with a cold engine and your mpg will actually be closer to 35mpg unless you do some seriously hypermiling and grille blocking, engine block heater etc..
    Some will also buy the car for the pollution reduction like I would be interested in. If I could drive around Davis in EV mode and not spew pollution in the faces of all the joggers and kids riding their bikes then I would be happier indeed.
  11. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    He is in SoCal so he has a better chance than most of getting one. :D
  12. dorian10
    irvine
    "Toyota is now accepting Pre-Orders for the all new 2012 Prius Plug-In. These vehicles will be available in Spring of 2012. Customers who Pre-Order will be given the FIRST Prius Plug-In vehicles, even before dealerships are given vehicles for inventory." This the email I got, car is coming out in a year.
    Boston globe : "Toyota hasn't announced pricing, but said the premium over a standard Prius would be less than $10,000." I guess I just assumed the worst case , $10k premium.
    Thanks for ever-ones post , I kinda get now
  13. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    NP man. You're not the first to think "Wth? How is this of benefit to anyone?". :)
  14. dorian10
    irvine
    Nobody kill me but, I'm also considering a VW Jetta Sportwagen TDI Diesel . I drove one, after renting a Prius for a weekend. I was very "shocked" about how much I enjoyed driving the Turbo Diesel. Reports of 45mpg avg, negatives its a VW, and diesel is more expensive then Premium fuel.
    Pluse,s it's FUN to drive, had a smile on my face the whole test drive.
    Just for the record I drive a gas hog Mercedes S500. I like my car, but hate it at the gas station !
  15. bisco
    50,800
    now, it all makes sense.
  16. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    Why would we hate you? It's a cool car and if it fits your needs and you don't mind the reduced fuel economy and reported reliability then go for it. You'll still get great gas mileage as long as you don't drive too many city miles and short trips (34ish mpg avg.).
    Fun is defined differently by each person. I grew tired of sports cars/trucks where the only fun to be had was speeding or corner carving (still speeding). I can cruise along in my Prius and have much fun by trying to bring my MPG up or see how long I can glide while using no fuel etc.. The Prius is a different kind of fun. More like a video game where finesse is the key to success. :)
  17. dorian10
    irvine
    F8L , I rented the Prius for the weekend, and yes it did become a game. I became obsessed to try and get the "High Score" w/ regards to MPG. My friend bought one, and she loves it, her other car is a Porche boxter. I. going to buy something shortly, glad you "get me"
  18. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    Putting aside that some can charge more then once a day, larger capacity charge/discharge rate battery will improve MPG, so you might actually see better MPG all around, even after the initial charge is gone.
    Investment recovery may actually be far less then 25yrs, would be interesting to see real life numbers.
  19. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    It's all good homie. I wish you the best of luck with whatever car you purchase. :)
  20. billnchristy
    billnchristy Active Member
    924
    123
    GA
    2016 Chevy Volt
    My general complaint with the Prius is its handling but I have recently added a strut tower bar and had to replace my bald Yokohama avids and now I have a car that handles very well for its size and weight.
    I can now make up for its general lack of speediness by taking corners faster and having fun that way.
    But yeah...get what makes you happy.
