I think I was taken
Discussion in 'Gen 2 Prius Technical Discussion' started by Falcon Raptor, Jan 31, 2010.
  1. Falcon Raptor
    Falcon Raptor New Member
    Someone tell me if I should be upset. My GenII was missing and running rough, at least it seemed that way, especially in damp weather. I took it to the dealer, he had it all day and when I picked it up, I had almost a $300 bill. Dealer said they checked it out and the distributor cap was cracked, so they replaced it. On the way home, it still runs rough.
    I'm not sure if I should complain or not. Maybe it was cracked and needed to be replaced, but something additional is wrong.
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    If that's what they charged you for, then yes, you should be upset b/c there is no distributor cap.
  3. Sandy
    Sandy Hippi Chick
    860
    53
    Ocala,Fl
    LOL yep you were taken..
  4. patsparks
    10,664
    567
    Adelaide South Australia
    If it wasn't such a bad mistake to have to pay for you would laugh. Distributor cap? Hahaha.
    If there was a distributor cap on the invoice ask the service writer to point out the cap under the bonnet to you so you can see the new part for yourself.
    A distributor cap looks something like this.
    You won't find one under the bonnet of a Prius as it has direct fire coils on each spark plug.
    The coils have been known to fail, I know a cheap fix if you get to the problem soon enough.
    Clean the coil with petrol to remove all traces of dirt then dry well and brush paint the outside of the coil with enamel paint paying particular attention to any cracks or seams. This has worked for me every time.
    Do not continue to drive a Prius or any modern car when it is misfiring, it can harm the catalytic converter.
    SFO likes this.
  5. ronhowell
    ronhowell Active Member
    681
    32
    Cypress, CA.
    So how is the spark plug spark distributed to each ICE cylinder in turn?
  6. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
    Through a solid state electronics system that has no more moving parts. In place of the distributor, there are multiple coils that each serve one or two spark plugs. A typical 6 cylinder engine has 3 coils that are mounted together in a coil "pack". A spark plug wire comes out of each side of the individual coil and goes to the appropriate spark plug. The coil fires both spark plugs at the same time. One spark plug fires on the compression stroke igniting the fuel-air mixture to produce power, while the other spark plug fires on the exhaust stroke and does nothing. On some vehicles, there is an individual coil for each cylinder mounted directly on top of the spark plug. This design completely eliminates the high tension spark plug wires for even better reliability.
    Ignition Systems  A Short Course
  7. ronhowell
    681
    32
    Cypress, CA.
    Yes, but looking at my own 2008 Prius, it appears that each spark plug has it's own coil mounted on top of the plug. I am guessing that this module contains both the primary and secondary coils. The pulsing of the primary current via the engine ignition ECM generates the strong magnetic field and high (10k+volts?) in the secondary coil to produce the plug spark.
    Since my ancient degree was in aero not EE, I'm guessing here. Enlightenment is welcome!
  8. Patrick Wong
    18,200
    6,490
    The engine ECU sends a pulse of primary current to the appropriate igniter when it's time to fire the associated spark plug. A knock sensor is bolted to the engine block to provide feedback to the engine ECU regarding whether ignition timing is too advanced or not.
    This is basically correct. The high voltage output is probably more in the 20KV range.
    Back to the OP's post:
    What is the odometer reading?
    Please provide the part numbers and descriptions of the replaced parts listed on the repair invoice. Then we can comment on what was actually done to the car. It could be that your service advisor is illiterate in modern automotive technology, and in good faith thinks that Prius really has a distributor system, like a car dating back to the 1980's.
    Further, has the check engine light come on, since the car was retrieved from the dealer? If yes, then a DTC will have been logged and it will be easier to determine the cause of the engine misfire. If not, then basically the misfire will be due to either a spark igniter, a spark plug, or a fuel injector. However one problem is to figure out which cylinder has the fault.
    In rainy weather, water may drip from the cowl to the valve cover. It is possible for water to then enter a spark plug well, causing a misfire. Although a rubber O-ring around the igniter is supposed to provide a seal, since only one bolt secures the igniter to the valve cover it is quite possible for the O-ring to leak.
  9. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Wasn't there a service bulletin on the 04's to reseal the hood someway to prevent water dripping on top of the engine to prevent this misfiring from ahppening?
  10. toyotechwv
    toyotechwv Toyota Technician
    474
    251
    Princeton, WV
    At our dealer no work is performed without an explanation of diagnosis, a written estimate, and CUSTOMER approval. Are you saying they did $300 worth of work without your consent?
  11. Patrick Wong
    18,200
    6,490
    Yes, the TSB advice basically was to put a bead of sealant on the seam at the center of the plastic cowl cover.
  12. priushippie
    priushippie New Member
    330
    Pennsyltucky
    Yep, Your stealership took you to the cleaners! Take him to court an clean him out! What is the name of the stealership? Let us all know!
  13. octavia
    octavia Active Member
    968
    137
    Beautiful Oregon
    The bright side to this might be that they told you a part that is clearly not replaceable. This will make it much easier for you to question the charges and probably get your money back.
    Also, if they are a Toyota dealer you may have some recourse through
    Toyota and it would be nice if you, as patrick has suggested, post more detailed information about your experience here. The experts who frequent this board will be able to give you precise information and this massive consumer base of smart people would like to know what dealers to avoid if indeed, they purposefully mislead and over charged you.
    Really sucks to have a dealer you can't trust! :(
  14. Politburo
    Politburo Active Member
    971
    208
    If OP is correct, this is more of an issue than simply getting their money back, imo. It's outright fraud, and deserves prosecution.
  15. mike lipke
    mike lipke New Member
    89
    MN
    Ben Franklin said to "Believe half of what you see and none of what you hear."
    Ben could not have known about the internet, but if he did, the percentage might have been even lower.
  16. freo-1
    freo-1 New Member
    180
    22
    Mass.
    You should report the dealer to the Toyota regional office. With all the bad press they are getting right now, they should only be too happy to get this sorted out.
  17. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    Falcon hasn't replied yet. I wonder what's going on.
  18. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    Someone took the steam generator out of his computer.
    Tom
  19. octavia
    968
    137
    Beautiful Oregon
    :bounce:
    You are so baaaaaad Tom.
  20. ronhowell
    681
    32
    Cypress, CA.
    Yes Octavia, we oldsters on PC know how bad Tom is .... there's just no stopping him!
    Which is good. This crazy world needs a few laughs to lighten it up.
