I want to hardwire a Valentine One in my 2003 Prius
Discussion in 'Generation 1 Prius Discussion' started by Irrenarzt, Nov 17, 2012.
  1. Irrenarzt
    Irrenarzt Junior Member
    35
    Half a mile from Tucson
    2003 Prius
    I
    Is there a 12v switched wire available near the light module on the front of the headliner? I know people will think "why on earth do you need a Valentine in a Prius" but I like knowing where the police are...
    TIA.
  2. Yakuzahi
    Yakuzahi Junior Member
    85
    Long Island NY
    The Prius can do 80 or 90 miles an hour? Sure it can, so why not have a Valentine with you?
    I'm not so sure if you have a 12v IGN near the light module, but you can test it with a wire tester.
    Why do you want to connect your V1 inside the engine compartment? I connected mine to the IGN wire coming out of the IGN switch and ran the wire all the way to the sun visor.
  3. Irrenarzt
    35
    2003 Prius
    I
    Thanks for the reply Yakuzahi. I don't want the switched 12v wire to be in the engine compartment, I want one to be directly overhead the driver, near the rear view mirror. I was hoping the personal light above the rear view mirror would have one available, so I can mount the V1 high on the windshield so it's most effective and out of the way. I have one mounted now but am using the cigarette lighter for power so I have an unsightly cord to deal with.
  4. Yakuzahi
    85
    Long Island NY
    If you have the extended hot connection hard wire, and you can remove the dashboard panel under the steering wheel and the ignition cover. All you need is a Philips screw driver and a 10m socket with a ratchet, and you can follow the ignition harness. Look for the black/yellow (+) wire; this is the ignition wire. The V1 will power after the car is on or running. Then lead the wire all the way to the top of the windshield.
  5. Irrenarzt
    35
    2003 Prius
    I
    OK thanks. I will do it that way. I don't have a tester so I need to know a reliable switched source wire to work off of.
  6. ChapmanF
    16,948
    If you don't want to go digging for an IG-switched circuit but there is a constantly-powered circuit nearby (as for the map light), another option is a voltage-sensitive switch. These are sometimes sold prebuilt as "battery protectors" that shut off below 11 volts or so, with the idea that you'll hook up some load you want to run even with the ignition off, but shut off before the battery is really drained.
    The same idea, only built with a higher voltage threshold, makes a reliable Prius READY-ON detector, because a fully charged lead-acid battery is 12.72 V but the Prius converter puts out 13.8 in READY. So if you set the threshold between those values you can have something powered when you're in READY and off when you're not.
    I used the idea here: that was physically large because I wanted an expandable multicircuit fused distribution thingy for the trunk. If all you want is a single circuit for a small detector, you shouldn't need much space for the necessary components.
    -Chap
    joedirte likes this.
  7. Irrenarzt
    35
    2003 Prius
    I
    Thanks Yakuzahi. I got this done today and it's working well. I have the V1 about mid windshield but it is powered via the black wire with the yellow stripe. Plenty of room underneath there once you remove all the covers...
