ICE 1 sec start/stop
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by grharman, Nov 15, 2013.
  1. grharman
    grharman Junior Member
    23
    arkansas
    I wanted to find out if anyone else has experienced this. I have a 2013 Prius Three. If I drive somewhere(engine completely warm) and stop, like at a store, come back 5-10 mins later, hit the power button, sometimes the ICE will start and immediately shut off, like within 1 second. It can't be the warm up cycle as the ICE is at normal operating temperature. Anyone else experienced this? I guess it is not a issue, as one of the 20 computers is doing this and there are no lights(like cel).
  2. Les_PL
    Les_PL Active Member
    317
    249
    Gdynia, PL
    Perhaps the area where is the coolant temperature sensor is getting a little bit colder and only after starting the hybrid system the circulating (already warm) liquid warms up the sensor back? Is the cabin heating ON or OFF? It may also play a role.
  3. Former Member 68813
    3,524
    983
    US
    Happened to me once. While waiting at a red light in ready and fully warm. Some kind of glitch. At least it was not a gas pedal glitch.
  4. macman408
    macman408 Electron Guidance Counselor
    1,179
    367
    Yeah, I've had that a couple of times. It might also be affected by the coolant around the sensor cooling off, so the engine starts running and the coolant gets pumped around, and the circulating coolant from the engine is warmer, so it shuts off again.
  5. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    same here, a couple of times. have mo idea why. also had times where the ice ran for no good reason... full charge and engine warm.
  6. grharman
    23
    arkansas
    But the water pump is electric, which means the engine does not circulate the water. IDK, I guess I'll just drive it.....
  7. Les_PL
    317
    249
    Gdynia, PL
    Yes, but once you switch the car ON the coolant pump (and many others) comes to operational status. Except the brake boost, which lives it's own life :)
    xpcman likes this.
  8. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    If you press gas pedal while in P, ICE starts.
    Not sure why it would start when not pressed??
  9. Les_PL
    317
    249
    Gdynia, PL
    Not always :cool:
  10. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Sure it does. This function is put in for servicing at the shop (when they need the engine to run on demand).
  11. Les_PL
    317
    249
    Gdynia, PL
    It happened several times when I was waiting for something, getting bored and pressed the accelerator pedal just to see what will happen. Normally ICE starts but after few consecutive attempts it said NO! Perhaps the car send me a message "don't bother me when it is not necessary" ;)
  12. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    interesting... will have to try that.
  13. Former Member 68813
    3,524
    983
    US
    LOL, adaptive behavior?
    Sometimes the car surprises me too. I'm used to seeing ICE kick in every time I accelerate past the mid point in HSI. There was one day when it kept accelerating in EV past the mid point. Mind you, the EV button was not pressed. The best I can explain, traction battery was near full and ECU decided to burn the charge to make some room for regenerative braking,
  14. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Were you in ECO mode?
    Had this happen too after coming off a long hill with a very full charge. Think I got up to like 43mph on a flat road before the ICE kicked in.
    elementnomore likes this.
  15. OzPrius
    OzPrius Junior Member
    43
    New South Wales Australia
    Yep in ECO mode with full charge, between 65 and 70 km/h. Or about 45mph.
  16. macman408
    1,179
    367
    The past couple of times I've noticed this, it has happened when the car starts with the ICE coolant above 65°C (thus, no warmup cycle), and then the temperature drops below 65° and the engine turns on.
  17. Grren4ever
    Grren4ever Active Member
    347
    167
    Never happened to me but now that you've mentioned it, I'll probably be more aware of it and it WILL happen...lol. Will report back if it does, I have a 2013 prius base model.
  18. David Beale
    David Beale Senior Member
    5,963
    1,985
    Edmonton Alberta
    You guys are all wrong. BY DEFINITION whatever the Prius does is -NECESSARY-! ;)
  19. OzPrius
    43
    It almost seems like it is rev matching. Just a thought.
