ICE starting/running in Park
Discussion in 'Gen 2 Prius Technical Discussion' started by Johno1087, May 14, 2009.
  1. Johno1087
    Johno1087 New Member
    Hastings, New Zealand
    2001 Prius
    Hi all,
    I hope this is'nt too obviously a newbie question:welcome:. I have a 2000 NHW11 Classic.
    After the ICE has completed warmup, when I stop and select Park the ICE starts just before I turn off the car and again on startup (even when the ICE is at normal operating temp). Is this normal? and is there any way/techniques/tricks to stop the ICE starting all the time when shifting into Park?
    Thanks :):):):):)
  2. tochatihu
    tochatihu Senior Member
    9,467
    3,656
    Kunming Yunnan China
    2001 Prius
    Hi N Zed. Yeah, they do that. We used to call it 'housekeeping', and regarded it as perhaps unnecessary. If you pause at 'N' before you shift 'P' it won't happen.
    Or, you go to P first then N then back to P. I forgot which procedure works. Car is not here...
  3. Johno1087
    2001 Prius
    Thanks DAS, I'll give it a go.
  4. Inches
    Inches Member
    117
    San Mateo, CA
    I have not noticed that. When I get gas I pull up to the pump and hit P, pump the gas and drive off. The ICE never comes on while I'm filling the car.
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    It can, and will eventually. Refilling while in Park has been the topic of numerous posts. I don't recommend it for two reasons:
    1) It is illegal in most areas.
    2) The Prius fuel system has several automatic valves which are not properly configured for refueling when in Park.
    Tom
  6. hill
    8,591
    Not that it stops a ton of us from doing it anyway.
    :eek:
