if i replace hybrid battery & transaxle am i good?
Discussion in 'Gen 2 Prius Technical Discussion' started by myfootsmells, Jun 28, 2008.
  1. myfootsmells
    myfootsmells New Member
    Pasadena, CA
    2002 Prius
    105,000 miles on the car.
    if i replace the transaxle and hybrid battery am i good to go for another 100k or what else??
    michael
  2. bwilson4web
    16,217
    It depends upon the quality of repair and how you subsequently drive it. Were those 105,000 miles you put on the car?
  3. AdamKPL
    AdamKPL Member
    118
    East Hampton, Connecticut
    Dumb question...but do you need to replace the hybrid battery @ 105K? Not sure what Toyota offered at the time but you might still be under warranty, check with the dealer.
  4. richard schumacher
    7,664
    1,046
    United States
    Yeah, what Adam wrote: why do you think they should be replaced?
  5. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    I think you'll be good for another 150k miles + WITHOUT replacing them.
  6. statultra
    statultra uber-Senior Member
    798
    31
    Edison,NJ
    2001 Prius
    just drive until u get constant turtle lights, then u need a new battery. the transaxle should last forever
  7. bwilson4web
    16,217
    Perhaps we have found "Prius Zero"; the beginning; the Alpha; the Gold standard of all Prius; the Prius that CNW Marketing reports has a life time of only 109,000 miles.
  8. Patrick Wong
    18,210
    6,510
    Hi Michael,
    Pls see this poll: http://priuschat.com/forums/generation-1-prius-discussion/45766-classic-prius-repairs.html
    If your electric steering gear was not previously replaced, that is a potential trouble spot.
    If the engine ECU is not at the current level, you may eventually have starting problems especially if you do not keep the throttle body clean and the spark plugs in good condition.
    The catalytic converter will probably fail at some point, and you probably need to replace the front struts/rear shocks now given your current odometer reading (if they have not previously been replaced). Look for oil seeping on the strut/shock body.
  9. Stefx
    Stefx Member
    336
    Off topic, but I'm curious as to how you can still owe 7000$ on a 6-year old car. Did you have it financed on a 8-9 year loan?
