If you love your car, you should clay it
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Much More Better, Apr 24, 2011.
  1. Much More Better
    Much More Better Active Member
    655
    163
    Finally, it is warm enough outside to give my car the love it deserves. Over the winter, I was limited to pressure wand washing, and not the wash mitt/double bucket technique. Surface bonded contaminant are everywhere, making my Bliz Pearl look peppered. The worse areas are the lower half of front doors, right behind the front wheels. Note: the after pic has some dots stuck onto the tape; it's not on the car anymore.
    Took me 4h, because it's easy to see on white, and I'm obsessive. If I had a darker color, I would only clay until it's smooth to touch.
    I followed it up with Meguiar's Deep Crystal Polish and 2 coats of NXT Tech sealant.
  2. macmaster05
    macmaster05 Senor Member
    4,050
    730
    +1 :D
    What clay bar did you use?
  3. Much More Better
    655
    163
    Mother's. I should try Meguiar's next time because I like their stuff.
  4. macmaster05
    4,050
    730
    ^ok good to know. I've heard that Mother's is stronger clay than Meguiar's. My friend has Meg's and we tried it, it didn't do much.
  5. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Agreed on claying. I've been using Clay Magic on my cars for a long time.
    Now you just need to figure out a way to remove that penny! :D
  6. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Nice work.:rockon:
    If you put saran wrap or thin plastic bag over your hand then slide you hand over the surface, the micro crud you can't feel with your bare hand will feel like sand paper. I find that easier than looking and it doesn't matter what color your paint is.
  7. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    I clayed for the frist time a couple years ago. Now it's a Spring / Fall ritual.
  8. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
    Ditto about the clay. I clayed one of my vehicles probably about 15 years ago for the first time and it made me a believer. I usually clay twice a year; after summer and after winter. Follow it up with some fine hand polish and then zaino and you'll have one beautiful showroom looking car.
  9. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    You can also claybar your windshield and get rid of all the micro-crud embedded in it. You need the plastic bag or plastic wrap method to tell when you have it smooth. I have found that it reduces glare, makes water bead up like it does on new glass, makes the windshield wipers more effective and the blades should last longer.
    It obviously won;t remove pits, but a surprising amount of windshield problems are micro crud stuck in the glass, just like the micro crud in your paint.
    Don't claybar plastic headlight lenses, it can take the coating off
  10. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
    Agreed about the windshield as well. Griots garage, where I get my detailing products other than zaino sealants, came out with windshield clay a little over a year ago. I don't know if it is different than the paint clay, but they made it blue (the paint clay is yellow from them). All clay pretty much does the same thing, some probably has smaller particles making it up, some larger, but honestly they all get the same job done IMO.
  11. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Griots is a good operation so I suspect there is some reason for different clay, but I use the same clay I use on paint and don't have any problems. Claying a windshield does seem to take lot longer than an equivilant amount of paint.
  12. stream
    2,977
    452
    Long Island, NY
    And once you get the windshield nice and clean with the claybar, you can apply your favorite polymer. I use RejeX. It minimizes bug splats, causes water to run off easily, and makes subsequent cleaning easier.
  13. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    How do you deep clean the headlight lenses without disrupting the coating?
  14. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
    Stream, have you used rain x and if so are you happier with using the rejex instead? Or do you use the rejex for simplicity to not have an extra product laying around the garage?
  15. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    You can Zaino it as well.
    I'd avoid the front side windows if you have the IV or V with water-repellant windows when it comes to claybaring or using any kind of abrasive.
  16. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
    I don't love my car, we are just good friends.
  17. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I don't use anything more than mild car wash and water.
    If they are hazed or otherwise screwed up, then they need some serious work that will remove the coating.
  18. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    That is an excellent point.
  19. stream
    2,977
    452
    Long Island, NY
    Never tried RainX. I have a bottle of RejeX that's so old I can't remember when I bought it (never used it for paint--only windshield, and wheels and exhaust tips where applicable/necessary).
  20. stream
    2,977
    452
    Long Island, NY
    I've found that some wax (I use One Grand Blitz, which contains no abrasives), applied with your fingers, and the use of a fingernail where necessary, works well.
