If you thought Mouse Motel was bad
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by hobbit, Jun 15, 2006.
  1. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    Refer to http://www.avian.org/~hobbit/pix/cowlgutter.jpg for the
    visual. I had been hearing *water* sloshing around in this area
    when driving or even just rocking the car, and took things apart
    this afternoon to investigate. Long story short: those two drain
    holes were *completely* plugged with organic matter, and there was
    about an inch of standing water in the whole cowl piece that just
    wasn't going anywhere. It was totally disgusting, like a little
    pond with a mucky bottom right there under my hood. As soon as I
    dug my finger around in there and pulled out a wad of brown goo,
    all the water on one side drained out behind the front wheel as
    it's supposed to, and then the same on the other side.
    Bottom line: it's worth pulling the wipers and plastic air baffle
    off every so often and cleaning out that black metal "rain gutter"
    piece under there. It does a very good job at keeping water and
    crud off the back of the engine, but apparently those holes aren't
    quite enough to keep it working right forever -- just like any other
    gutter, it needs periodic cleanout. With all the rain, pollen, and
    bits of trees we've had falling around here this spring, it was
    evidently just too much at once.
    _H*
  2. Sufferin' Prius Envy
    Sufferin' Prius Envy Platinum Member
    3,998
    D'oh! I too have heard the water sloshing around after wash jobs . . . and I live in an urban forest here in Sacramento.
    Guess what I am doing this weekend. :mellow:
    Any "how to" list to follow?
  3. hobbit
    4,089
    468
    Bahstahn
  4. tumbleweed
    tumbleweed Senior Member
    4,067
    690
    Eastern Oregon
    Thanks for the tip. I'll be checking mine soon.
  5. Sufferin' Prius Envy
    3,998
    Thanks hobbit!
    If it takes that much effort to gain access to the Mosquito Farm, I'll have to see if I can modify in an access port so I can reach the drains with a vacuum tube for clearing the clogs. I heard the sloshing within the first six months of ownership. My Mosquito Farm swamp must be breeding mosquitos the size of hummingbirds by now. :eek:
    Sounds like a rare Toyota design flaw. :(
  6. FL Buckeye
    FL Buckeye Member
    146
    WC Florida
    Thanks for the heads up. This is a great site!
    Where I live the live oak leaves get into every crack and crevice. I know this will be a normal maintenance check for me.
  7. glenk
    glenk Member
    109
    Fairfield, CA
    <div class='quotetop'>QUOTE(hobbit @ Jun 15 2006, 10:18 PM) [snapback]272000[/snapback]</div>
    This looks like a problem that many will experience over time.
    I wanted to confirm that you do indeed have to remove the wiper arms (steps 1,2) but not disassemble the motor and link assemblies?
    Tnx,
    glenk
  8. Kathleen2
    Kathleen2 New Member
    77
    Thank you for the information. I haven't had the problem but I thought I was just being too persnickety; as when I wash my car I clean under the hood also. I didn't even know those were drain holes.
    Kathleen
