I'm guessing you could run the PHV on the ICE only?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by priustexasbob, Jan 12, 2011.
  1. priustexasbob
    priustexasbob Member
    356
    86
    arrakis
    2015 Prius c
    I would guess that you could run the PHV on the ICE only. what if you didn't have electricity for a week (act of nature) but still had to run errands?
    this is the downfall of all electric vehicles and having it as your only driver, you could be screwed if you don't have electrical to plug in your car.
    50,800
    that's exactly right. when you run out of plug in juice, it's the same as our pri. you can drive forever as long as you can find a gas station. of course, you're dragging around a bit of extra battery weight.
  3. Tideland Prius
    16,401
    It functions as a regular Prius with Li-Ion batteries.
  4. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    And on that note - despite the heavier weight, it will still get better MPG than a stock Prius - even when you don't plug it in.
  5. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Why is that? Is it because the newer battery is lighter or just more efficient or both?
  6. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Without plugging-in, the two EV sub-packs are disconnected from system and stay in "fully depleted" condition (i.e. the minimum SOC allowable by Toyota).
    In long time, they will slowly discharge further to below the minimum. I wonder if this may deteriorate the batteries capacity and service life?
    In the final product Toyota may recommend minimum plugging-in strategy.
  7. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    The PHV Li batteries (3 of them) are heavier then the one Nickel battery in the regular Gen 3.
    The PHV HV battery has about one third more energy capacity than the Gen 3 HV battery (1.73 kWh versus 1.3 kWh), so it can regen more. It probably also gives longer EV range and speed (in HV mode).
    These are, to my opinion, the main factors in in achieving the slightly better milage in HV mode.
