I'm Seeing a lot of 3rd Gen Prius Missing Wheelcovers
Discussion in 'Gen 3 Prius Main Forum' started by cycledrum, May 14, 2011.
  1. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    ... and I don't like it.
    Seeing a 3rd gen Prius out there missing a hubcap, or two or three is becoming a common sight. Practically everyday, I see one missing a wheelcover. It's not helping image of the Prius IMO.
    Even the rental Prius I got yesterday was missing a wheelcover (no, I didn't pull it off, it came that way) -
    Doesn't this look funky to you? What do you think?
  2. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    It's relatively easy to install them incorrectly so that one of the latches is not sufficiently engaged, and it can still look properly installed.
    If you want to be sure, take a rubber mallet and tap lightly all the way around to make sure it is secure.
  3. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    I wonder if they have a tendency to fall off after they've been scraped on a curb.
    Whatever it is, things are not working well with the covers. Like said, I see 3rd gens missing covers all the time. Been seeing that for about 2 years. Makes the car look cheaper and gives people another reason to look down on it. Don't want that on a car that gets this kind of fuel economy ...
    Mostly on highway, and city is only a couple less.
  4. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    Yes, if you curb the wheels, like ride up on a curb, and then "fall" off the curb, the hub cap can catch the curb and fall off.
    I did that on a rental :eek: but the hub caps were bolted on, so it took a chunk out. Luckily I didn't have to pay for it. Those hub cabs happen to stick outside of the wheel about half an inch.
    The Prius hub cabs sit inwards more, the tires stick out a bit, so the likelihood of them catching is less, but not impossible.
    I saw some chromed OEM 15" wheels the other day, and in fact the dealer recommended to me to take off the covers and chrome the wheels for a better look. I don't really like the chrome look but it can look ok.
    I really like the look of the Yaris 15" alloys, but they only use 4 bolts so no go there.
    I would like some snazzier 15"s. I'm into getting higher FE so I don't want to get 17"s just yet.
  5. macmaster05
    macmaster05 Senor Member
    4,050
    730
    Yeah I agree Cycledrum. It's ugly. It's worse than the old cars or even Corollas with missing hubcaps.
    As far as "image" goes, the problem is a majority of Prius owners don't care or won't even notice. Cause they're old. Or noobs. Which makes the rest of us, who do care, look bad. And thats f***d up! LOL.
  6. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    The friggin problem with Corolla hub caps is other owners or people just like to come by and swipe them off of your car when they're missing theirs. My car is not the parts shop.
    I happen to think Prius owners are less likely to be thieves.
  7. macmaster05
    4,050
    730
    Time and exposure bro. Most people don't know what the heeeel is going on down there on the Prius wheels, and probably don't suspect there's anything to pry off. When they find out, we might see the same kind of theft.
  8. Thai
    Thai Prius Neophyte
    1,197
    89
    Actually, b/w the wheel cover on or off, i prefer the off look without the plastic cover.
    2 people like this.
  9. geeter
    geeter Member
    208
    16
    Chicago
    Took mine off at the dealer when I bought the car. I would rather run on steelies than plastic hub caps.
  10. Thai
    Thai Prius Neophyte
    1,197
    89
    They are alloy rims under the cover, right? They are not steelies, are they?!
  11. ETC(SS)
    6,841
    I believe that they're alloys.
    Gee.....maybe I need to remove one of my covers to fit in???
    Whadaya think? RR, RF, LR...or LF???
  12. Mendel Leisk
    40,236
    I know I'm always harping about past Honda's, but anyway:
    Their wheel covers are held on by the lug nuts. Each lug nut has a plastic ring in a groove, a ways up the sidewall of the nut. So the base of nut holds the rim, the plastic ring holds the cover.
    With this setup they will never fling off, and theft is a little harder, you have to remove lug nuts. If there's a locking lug nut it typically doesn't have the ring. But still, having to deal with lugnuts to take off someone's wheel cover is a bit more complicated.
  13. dogfriend
    7,512
    1,188
    Carmichael, CA
    They look better without the plastic covers. Maybe someone realized that and is going around removing them. The reason they don't remove all 4 is because it is too time consuming and they might get caught. If they remove one, then the owner will eventually remove the rest so all wheels match. :madgrin:
    GCPExit12 and cycledrum like this.
  14. ETC(SS)
    6,841
    That's how the center caps (also plastic) are attached on my truck. I've whammed the snott out of my wheels off-road and haven't lost one yet.
    What can I say?
    Toyota's drive train seems to be first rate, almost bullet proof....but some of the fit and finish choices that they made for the rest of the car have left me shaking my head in disbelief.
    Your best bet would be to yank off the plasticky covers, and go to Lowes and get some 1.5" knock out covers (bend the tabs out a little) and just deal with the tuning-fork alloys beneath.
    The wheels will be easier to keep clean, and you can save the plasticky covers to sell on eBay.
    Just a thought! :cool:
  15. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    Keep wheel covers to put back on for trade-in time to get plug-in or 4th gen or v or c or .... :D
  16. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    As the car matures and it's immune system develops, it develops the ability to de-uglify itself and it spontaneously rejects the wheel covers.
    6 people like this.
  17. Yates
    Yates New Member
    Raleigh, NC
    We had an '06 Corolla that kept loosing wheel covers too. Defective design. Toyota stopped selling the wheel covers original to car.
  18. FirstNLast
    FirstNLast Geek & PROUD of IT.
    Richmond, VA
    HAR HAR! :heh:
    I'm with you xs650!
    The Prius is just spontaneously rejecting the plastic hubcaps & flinging them off one at a time so you don't notice.
    JohnB
  19. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    Since the wheels v. covers preference comes up frequently, I'm wondering outloud if Cycledrum is really asking to address the big elephant in the room: Are wheel covers coming off due to supplier defect in the cover clips. I doubt that Toyota would admit a problem since it's easier to blame it on theft and/or curb banging. Seems as if too many Prius are loosing their covers. If it's curb banging, you'll see side wall scuff marks. If you get in the habit of walking around the car before getting in, you'll notice if it's theft.
    I'm not having the problem, nor seeing it on other Prius, so I can't validate one way or the other.
  20. Don3755
    Don3755 New Member
    Space Coast, FL
    Thinking of taking mine off as the wheels look good without them. Then I can reinstall them for resale down the road.
