Immobilizer All Keys Lost Reset - But can't get SKS Keys Registered
Discussion in 'Gen 2 Prius Main Forum' started by DashingDave, Feb 18, 2025.
  1. DashingDave
    DashingDave Junior Member
    37
    Monterey
    Can you help please ?
    Read dozens of posts on "All Keys Lost" resetting Immobilizer,
    but found exceedingly few about resetting the new SKS FOB Key Immobilizer Chip afterwards
    - which is where I'm stuck.
    Hardware -----------
    TechStream (ver 18.00.008)
    MVCI J2534 Cable v 1.79? - Possibly (not certainly) version shouldn't matter as
    it was used to successfully reset Immobilizer.
    Toyota Prius Smart Remote Car Key Fob MOZB31EG
    Software -----------
    Windows 7 SP1, 32 bit
    Java Installed
    .NET Framework 4.x - "Install Did Not Succeed"
    but .NET 3.5 is apparently "built in" to Win 7 and it appears to be there.
    Code from pin-online (Supports TS versions from 8-18, Octopus only vers 8-17)
    Process -----------
    Using TechStream. From System Menu - Immobilizer - Utility, Immobilizer Code --
    *** Immobilizer ECU Success - "All Keys Lost" Reset - showed 5 key slots available - 0 used.
    *** HOWEVER, now Can Not get a new Key FOB registered
    Firing up TechStream gets --
    "Reduced Functionality
    "Techstream was unable to access the network
    "Some information may not be available.
    "Features such as campaign validation will not function in offline mode"
    So I choose "Offline Mode"
    Under Immobilizer selecting "Transponder Code Registration (STR-09-002)"
    It asks me to "Remove Key from Key Slot"
    (But the key was not in Key Slot - because it never gave an instruction to put it in.)
    So I put a new FOB in for 5 seconds and then removed it.
    "Insert the key back in slot - did that.
    Gets me -- "Transponder Code Registration has failed.
    "The Inserted Key is not currently registered. Do you want to try again."
    Retries fail half a dozen times.
    When I try to register the key from Smart Key (on System Menu)
    It responds --
    "System Select Wizard (S303--05)
    "Selected System is not responding or not available.
    "Please check repair manual for applicable systems"
    Subsequently --
    Tried Re-Re-Setting Immobilizer - Failed 8 Times
    I'm pretty much out of things to try.
    What jumps out at you that I'm doing incorrectly?
    Thank you
    #1 DashingDave, Feb 18, 2025
  2. rjparker
    rjparker Tu Humilde Sirviente
    9,285
    5,659
    Texas Hill Country
    My understanding is you need the higher "Security Professional" access. To make things worse, Toyota has changed Techstream to a new version and has effectively disabled some features on the old version such as the ecu software access. Not sure about new key additions but that was always difficult without a working fob in hand.
    Many locksmiths do have Security Professional access, it might be necessary to contact one of them or the dealer.
    DashingDave likes this.
  3. DashingDave
    37
    Monterey
    Thank You RJParker !
    Wondering if I should try an earlier version of Techstream?
    The European Pass-Code folks only support up to version 17 - hmmm.
    I also had Techstream version 7 running (the 6 digit Seed-Code kind (pre 96 digits))
    but the Pass-code pin-online calculators only start with version 8.x
    You indicate techStream has "disabled some features on the old version"
    But if the software was released years ago - and since the Prius was built years ago
    - can't imagine how Techstream could modify any old software - except to re-release old versions.
    Not impossible, but never heard of any software company doing that.
    So maybe I should try getting Techstream version 8.x or 17.x running?
    #3 DashingDave, Feb 18, 2025
  4. rjparker
    9,285
    5,659
    Texas Hill Country
    The disabled ecu calibration (software) capability required an online access to retrieve the software. That access failed on the old version even though a user had purchased a legal version with a current subscription.
    Security of the immobilizer was always difficult and required the Security Professional access.
    Even with a hacked version many have reported problems with aftermarket interfaces.
    There may be a way but pro locksmith help is guaranteed when no working fob is available to make adding a fob easier.
    This response "The Inserted Key is not currently registered. Do you want to try again" suggests that function needs a working fob.
    #4 rjparker, Feb 18, 2025
  5. mr_guy_mann
    mr_guy_mann Senior Member
    3,921
    1,887
    NJ-USA
    Where did you get the fob? I don't know if that's the correct # for your car, but I wonder if it has a good RFID chip or not. Or if the dash slot works. (A locksmith should have a tool to check that stuff).
    Were there any codes in immobilizer-SKS systems (other than "no valid key" codes)?
  6. DashingDave
    37
    Monterey
    They (I bought two) are advertised as a "Key Fob fits 2004-2009 Toyota Prius Smart Keyless Entry Remote for SILVER LOGO (MOZB31EG)"
    So it claims to have the right number. (They are not Black Back keys - a common mistake.)
    Don't know how to test a key FOB, other than I have tried both - with no luck.
    One hardware failure is not unusual, but two - seriously unlikely - unless they suffer from the same PC board design or manufacturer error.
  7. MAX2
    MAX2 Senior Member
    1,335
    418
    101
    Third planet from the Sun
    When both are bought from the same seller, it is not a coincidence.
    Have you disassembled the key fobs?
    Is there a board chip for the radio channel?
    Is there a chip hidden in the plastic that looks like a small black and gray seed?
  8. DashingDave
    37
    Monterey
    Thank you for trying.
    No. I quoted every error returned (including exact capitalization. Note -your quoted text is not what I reported. See original post.)
    #8 DashingDave, Feb 19, 2025
  9. DashingDave
    37
    Monterey
    Yes, I disassembled both, they have something the same size & shape as the RFID chip.
    MAX2 likes this.
  10. MAX2
    MAX2 Senior Member
    1,335
    418
    101
  11. DashingDave
    37
    Monterey
    Thank you for hunting down the pictures of the FOB insides.
    I did answer above - Yes, each has "they have something the same size & shape as the RFID chip."
    But I examined them - there are no numbers identifying them as RFID chips.
    #11 DashingDave, Feb 20, 2025
