Installed BT Stiffening Plate
Discussion in 'Gen 2 Prius Accessories & Modifications' started by mrblaise, Apr 25, 2008.
  1. mrblaise
    mrblaise Go Lakers!!
    2,248
    525
    Southern California
    I received my BT Stiffening Plate through the Priuschat store. Thanks again Danny for seeing that I received everything so quickly. First of all, it was a breeze to install. You don't need jack stands or a hydro lift to install the plate. I merely laid down on my back, reached under and took the original plate off with a socket wrench. I then did the same thing and installed the BT Plate with a torque wrench. The whole procedure took less than 10 minutes. Now, for the performance of the car. I'm a pretty analytical guy, and I definitely feel a difference in the ride. This isn't in my head; it's in my car!!! From my perspective ... it was a worthwhile purchase.
  2. montenido
    montenido A 2 Prius household
    23
    Calabasas, CA
    I installed the stiffening plate after upgrading my tires. For me the biggest increase in handling is definitely gained through better tires. I'm not so sure about the plate. It is a nice piece of work and bolts up easily as you stated. But I think I might have noticed a bigger improvement in handling if I had stayed with the terrible integrity tires. Anyway, I am glad you like the plate.
  3. ceric
    ceric New Member
    1,114
    Fremont, CA
    I am with Montenido on this one.
    I got way more gain in handling thru wider tires than the plate.
    However, the wider tires hurt MPG, but not the plate.
    I did a fairly scientific test on the plate in term of roadholding g-force.
    It did no improvement that I observed. However, I definitely feel the
    Prius is more solid (rigid) when it goes over bumps and railroad crossings.
  4. mrblaise
    2,248
    525
    Southern California
    This is where I felt a major change as well .....
  5. Genoz World
    Genoz World ZEN-style living
    797
    La Canada
    hey people, i'm thinking of converting my regular prius to the touring suspension, i'm gonna ask you a question here.
    when i looked under my car in the first oil change, i did NOT notice any type of bracing under the car. am i dreaming about this? am i wrong?
    does the touring package have this upgraded brace?
    thanks for your help
  6. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
  7. patsparks
    10,664
    567
    Adelaide South Australia
    It is just a short plate with holes in it that goes across the bottom of the "centre tunnel" for want of a better name for it. It is under the exhaust pipe. The BT plate would be less inclined to flex under compression.
    I just got back from a 3000km journey in varying winds and speeds up to 172km/h (on the speed limiter) and the car was rock solid on the road on stock Michelin XM1 tyres and BT Tech plate.
  8. Genoz World
    797
    La Canada
    thank you! i'll check it out!
  9. Mead5.0
    Mead5.0 New Member
    Meadview Az U.S.A.
    I may have missed it ,but I would like to know if anyone has installed the brace on a touring model? These models ride and handle so well I would like to know if there is an improvement. Thanks, Nick. 2008 touring, silver.
