installed Toms front & rear lower braces- WOW
Discussion in 'Gen 2 Prius Accessories & Modifications' started by sc_trojan, Nov 24, 2007.
  1. sc_trojan
    sc_trojan New Member
    33
    los angeles
    after reading all of the posts, I have finally decided to install some of the Toms braces. I called Carson toyota and purchased what they had in stock- the lower front and rear braces. I had them installed for $80 at a very reputable alignment shop- (he races porsches on the weekend and had a Ford GT in one of the bays). He actually liked the work of the Toms braces and was surprised with the quality of the shims that were included.
    Long story short, these two bars really made a significant difference. So much so, that I ordered the TRD sportivo as well as the upper strut brace and the floor brace. While I do not expect the car to transform into a mini cooper, I am hoping that these suspension upgrades will finally make me enjoy driving this car.
  2. Tideland Prius
    16,402
    wow, good to know. Thanks for sharing!
    Is it still susceptible to crosswinds?
    Do you have the wider 195 tyres?
    or are the braces meant make the car more composed while cornering?
  3. sc_trojan
    33
    los angeles
    <div class='quotetop'>QUOTE(Tideland Prius @ Nov 24 2007, 10:45 AM) [snapback]543610[/snapback]</div>
    I have the scion 215/45 wheels/tires. These tires are a much rougher and noisier ride than stock. I also noticed a significant drop in MPG.
    The braces help with the turn in response. Previously, I have noticed that when you turn the car at higher speeds, it takes a while before the front of the car does what you intend, the back takes even longer to respond. The car is now much quicker to respond.
    Additionally, I now have more confidence with higher speeds when going up/down the onramps/offramps.
    I have personally always felt that this car is almost dangerous/scary to drive at high speeds (70+ mph) due to the lack of response from the suspension and the susceptibility of crosswinds. Hopefully all of these suspension changes I have planned will make for a safer handling car at high speeds.
  4. apriusfan
    apriusfan New Member
    6,050
    205
    S.F. Bay Area
    <div class='quotetop'>QUOTE(sc_trojan @ Nov 24 2007, 10:39 AM) [snapback]543607[/snapback]</div>
    Glad you are liking the TOM'S braces. It still amazes me how they can transform the car's handling - each time I get a loaner Prius from the dealer, I am reminded of how much room for improvement there is.
    Out of curiosity, what are you trying to achieve with the TRD Sportivo suspension and the floor stiffening plate? Hopefully, you are aware that you will have clearance issues with the floor stiffening plate and the exhaust.
  5. sc_trojan
    33
    los angeles
    <div class='quotetop'>QUOTE(apriusfan @ Nov 24 2007, 12:09 PM) [snapback]543647[/snapback]</div>
    I guess I want even sharper turn in response, firmer/more performance orientated ride (is that an oxymoron with a prius?) Maybe get the prius to handle like a civic si??
    In terms of the clearance with the floor stiffening plate and exhaust, I read on the forms that one person simply put some exhaust wrap on the bar where the exhaust rubbed. Yes, with the exhaust tape, there will still be rubbing, but it won't be metal on metal so the noise should be softened/less harsh.
  6. dculber
    dculber New Member
    29
    hot as hell, Phoenix Az
    <div class='quotetop'>QUOTE(sc_trojan @ Nov 24 2007, 11:39 AM) [snapback]543607[/snapback]</div>
    did they have it in stock, if not how long is the wait?
  7. dculber
    dculber New Member
    29
  8. dculber
    dculber New Member
    29
  9. apriusfan
    6,050
    205
    S.F. Bay Area
    <div class='quotetop'>QUOTE(sc_trojan @ Nov 24 2007, 04:27 PM) [snapback]543716[/snapback]</div>
    Sharper turn in response typically doesn't come from firmer & lowered springs and shocks which is what the TRD Sportivo consists of. Your ride criteria should be addressed with the TRD Sportivo. I doubt you will see as much improvement after fitting the floor stiffening plate as you saw from the front and rear suspension braces. In the MINI community, a floor stiffener goes on when the last 5% is needed for autocrossing.
    Keep us posted on the results of your journey into the modification zone.
  10. dculber
    dculber New Member
    29
  11. sc_trojan
    33
    los angeles
    <div class='quotetop'>QUOTE(Dead Ringer @ Nov 24 2007, 11:40 PM) [snapback]543885[/snapback]</div>
    They said parts should arrive sometime in Jan.
    <div class='quotetop'>QUOTE(apriusfan @ Nov 24 2007, 11:08 PM) [snapback]543876[/snapback]</div>
    Thanks for the input. I honestly feel that the $1000 spent on the braces/install was well worth it. I have the sports adjustable air suspension on both my porsche and mercedes, so I figured that a firmer ride in my prius is what I prefer/accustomed to. The floor stiffener just a couple of hundred, so I figure I just order it. If that bar was $1000, then I probably wouldn't get it. Same goes with the $250 strut brace- since I am installing the TRD sportivo, it make sense to put the strut bar on at the same time to save on installation fees down the road.
    I'll keep everyone posted. The only problem is that I will be installing everything at once. Since I am paying for the installation, it is cheaper that way. Either way, I figure I will stiffen the chassis as much as possible. Hopefully for a couple of thousand, I will have a much more enjoyable/sportier ride.
  12. RonH
    RonH Member
    556
    <div class='quotetop'>QUOTE(sc_trojan @ Nov 24 2007, 07:27 PM) [snapback]543716[/snapback]</div>
    I, too, have felt that white knuckle experience on freeway interchanges and agree that much can be done. But I wonder if making a Prius handle like a Civic Si or comparing it to a Cooper in a previous post is practical? They're just a different class of car. I'll admit I'm been passed by in suspension technology, so perhaps I'm underestimating what can be done.
  13. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    Are there any efficiency gains (MPG) to be had from stiffening up the suspension? I would think that any excess bouncing (energy) due to soft suspension may reduce milage.
    In drag racing any movement other than forward is wasted energy. So when you see a car doing a huge wheelstand off the line there is a ton of energy wasted in getting the front of the car off the ground.
  14. apriusfan
    6,050
    205
    S.F. Bay Area
    <div class='quotetop'>QUOTE(RonH @ Nov 25 2007, 08:36 AM) [snapback]543945[/snapback]</div>
    Trying to get even close to the handling ability of a MINI is going to require a replacement of the suspension that is in the Prius. The MINI has a multi-link suspension in the rear which is completely different than the trailing link suspension that is in the Prius. The differences between multi-link and trailing link suspension are significant; the details of which are really quite technical and beyond the scope of this thread.
    That said, there is some room for improvement in the suspension of the Prius. How far you go down the path of improvement is what has recently been posted about. The front and rear suspension braces remove the 'slop' in the current suspension by tightening up all of the suspension mounting points. The floor stiffening plate similarly tightens up the connection between the front and the rear suspension. The TRD Sportivo tightens up the ride of the factory springs and shock absorbers. There is a trade-off between a tighter ride and ride harshness, which is a personal choice. Another way to get a slightly tighter ride with a minimal increase in ride harshness is to go with a Touring edition for the tighter springs and shocks. I personally dialed back the ride harshness by going with a taller tire sidewall (/60 series versus /55 series from the factory for the Touring edition) and 15 inch tires instead of the 16 inch tires of the Touring edition.
    While I don't think it is financially practical to modify the Prius suspension to compete with the suspension of the MINI, it is possible to get rid of the slop that is present in the Prius suspension as it comes from the factory. Hope this helps.
  15. apriusfan
    6,050
    205
    S.F. Bay Area
    <div class='quotetop'>QUOTE(F8L @ Nov 25 2007, 10:50 AM) [snapback]543982[/snapback]</div>
    That was a dialog that I had with the owner of the SigmaAutomotive.com website when I was ordering the TOM'S bits. I personally don't see how a tighter suspension could increase mpgs. Yes, you can take turns faster than before, which would increase the regeneration from coasting. However, with a slight application of the brakes, you are triggering braking regeneration which in my experience, produces a greater amount of energy created. As an example, there is a stretch of Highway 92 between U.S. 101 and I-280 in San Mateo that drops about 200 feet in elevation (Hillsdale Blvd to El Camino Real for those of you familiar with the area). If I coast down the stretch, by the time I am at El Camino Real, I am doing something like 80 mph and the battery display is still blue (upper-most bar before turning green, but still blue). Taking the same stretch with slight application of the brakes results in a completely full green battery display.
    Just my opinion, but I think the main benefit of the suspension improvements is more of a safety item (the car is less likely to spin (or it will spin at a higher g-force) than as it comes from the factory). But the increase in 'quality' of the ride - priceless. :)
  16. RonH
    RonH Member
    556
    <div class='quotetop'>QUOTE(F8L @ Nov 25 2007, 01:50 PM) [snapback]543982[/snapback]</div>
    Yes and no. The real job of the suspension is to keep the wheels on the ground. Can't go if they're in the air! While its obvious in turns, its a factor in straight-aways, also, especially for front wheel drives. Accelerating shifts the weight back, but too much and you're using your torque to lift the front end as you pointed out in dragsters. Too loose and your wheels are bouncing off the pavement. Too stiff and the body's center of mass is coupled to the wheels and tipping occurs. That's why active transmissions have been such a revelation in non-NASCAR racing where the suspensions tuning can be adjusted dynamically as the situation demands. I seem to remember F1 was going to ban them. Did that occur? Another example is mountain bike suspensions and I suppose motorcycle suspension, although I'm not as familiar with them. Too loose and you're wasting your energy pogoing the rear wheel up and down. Too stiff and your back wheel is hopping over every little bump.
  17. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    Watch it, this sort of thing will get you into *big trouble* here on PC!!
    [smile]
    So...how much overpressure will those Integrities tolerate, anyway...? In Prius-land, THAT'S performance!!
    [laughing]
    <div class='quotetop'>QUOTE(apriusfan @ Nov 25 2007, 02:39 PM) [snapback]544001[/snapback]</div>
    Again, it's impossible to put a number --any number-- on "improvements" (if we can even agree to call them this) to the car...except, of course, the price.
    I think, if you're happy with the way yours is, you should definitely keep it that way.
    If others prefer to modify their cars, that's okay too, as long as one does not increase the ride-height or other things which might (if you'll pardon the expression) impact me in an accident.
    But, debating whether or not it's worthwhile to alter the car, seems a bit like debating how many angels can dance on the head of a pin.
    Years ago, I was involved in a study, which examined the feasibility of uniform placement of controls in all passenger cars sold in the USA. In other words, no matter what brand of car you drove, the controls would look, feel, operate, and be placed in the same location, across the board. Wondering, how you'd feel about THAT...?
  18. apriusfan
    6,050
    205
    S.F. Bay Area
    <div class='quotetop'>QUOTE(Pinto Girl @ Nov 28 2007, 01:38 PM) [snapback]545406[/snapback]</div>
    I would be the last person to debate the merits of modifying one's car - I seem unable to resist the temptation to do 'something' to each of the cars I buy (whether it is to replace s/c reduction pulley, wheels & tires and shocks on my MINI or the DICE iPod controller, brake pads, wheels & tires and front and rear suspension braces on the Prius; if there is an improved aftermarket product, I want it). My only point is to be honest with yourself, don't use mpg improvement as a means to rationalize the effort (and expense) if improvement in mpgs is going to be doubtful at best.
  19. drees
    drees Senior Member
    1,782
    247
    I disagree. In all my previous cars, springs and shocks make a very significant difference in turn-in repsonse compared to things like strut-tower braces. The only thing that helped turn-in response more than stiffer springs was a large front sway bar.
  20. apriusfan
    6,050
    205
    S.F. Bay Area
    Wait till you make mods to the Prius. There are differences in the body stiffness that are not present in other cars. The Prius has been engineered for economy before all else. Body stiffeners add weight and weight reduces mpgs. Also, there is slop in the suspension from the rubber mounts that are fitted. The TOM'S Rear Suspension braces (there are two braces in the TOM's rear kit) compensate for slop in the rear suspension that springs and shocks do not.
    It is also possible that the wider tires that I have fitted contribute to improved turn-in.
