Installing a 2nd 12volt battery
Discussion in 'Gen 2 Prius Accessories & Modifications' started by ramattos, Jun 26, 2012.
  1. ramattos
    ramattos Junior Member
    57
    Bethlehem PA
    will the dc/dc converter handle enough power to charge a 2nd 12v battery? i work out of my car and i dislike turning it on for any reason so i was thinking of adding another 12v to the system with an isolator. is it even possible and is there a ignition live wire in the trunk to tap the isolator into?
  2. ramattos
    57
    Bethlehem PA
    by the way the other one would only be used for powering accessories
  3. drew_flux
    drew_flux Junior Member
    73
    22
    sydney australia
    why not just put a deep cycle gel cell in the back?
  4. lopezjm2001
    lopezjm2001 Senior Member
    1,146
    407
    Sydney Australia
    And charge it with a solar panel installed inside the back window.
  5. ramattos
    57
    Bethlehem PA
    i was thinking of using a solar cell in the back as well. but i have an older battery that came out of my old car and i was going to connect it up to a cigarette lighter and an isolator so that it can charge while driving and provide extra power to the main 12v battery.
  6. kenmce
    kenmce High Voltage Member
    1,543
    514
    NY
    My guess is yes.
    Of course.
    Nearest ones I know of are the cigarrette lighters up front.
