installing aut0-dimming mirror in 2010 Prius 3
Discussion in 'Gen 3 Prius Accessories and Modifications' started by lenjack, Dec 21, 2011.
  1. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    I have a '10 Prius 3, with the standard day-night mirror. I also have an autodimming mirror, with wiring harness, which I had used successfully on my '98 Camry. I'd like to run the wiring to the fuse block under the dash. What is the best way to safely remove the A pillar, to do this without interfering with the pillar air bag? I don't want the wiring to prevent the air bag from deploying properly.
    The mirror is basic, no homelink,compass,or any other extras. I know there is an always hot lead, an ignition switched lead, and ground.
  2. lenjack
    804
    114
    Pennsylvania USA
    Anyone? I know someone must have done this.
  3. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    actually, don't bother.The spoiler blocks the headlight sensor in the mirror, and it doesn't dim well.
    Use the search function, there's a few long threads about the mirror. I was able to pull power from the overhead console that powers the LED that shines when the lights are turned on, since it only needs to dim when it's dark. I'm thinking of buying a visor homelink button set and putting the original mirror back up.
  4. lenjack
    804
    114
    Pennsylvania USA
    I've had the overhead console down and I'm not sure I feel comfortable connecting to it. I still think I want to go to the fuse compartment.
  5. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    I found the "hot when headlights on" wire in the harness and tapped off that. For the homelink buttons, I used the vanity mirror lamp power. I didn't want to play with any more wires on that overhead console plug.
  6. lenjack
    804
    114
    Pennsylvania USA
    If I decide to go to the underdash fuse junction, I still need to know how to remove the pillar, run the 3 wires, and put it back together WITHOUT interfering with the airbag in the pillar.
  7. Aegison
    Aegison Member
    404
    32
    36
    Southeast MI
    I had an auto-dimming mirror with compass installed by a local trim shop for $25.
    For do-it-yourself instructions, here's a link to a very detailed explanation, with pictures, of an install on a 2004 Gen II Prius.
    ElectroChromic Mirror (ECM) Installation
    Hope it helps.
  8. phoenixgreg
    phoenixgreg Senior member
    1,157
    291
    66
    Phoenix
    lenjack: To remove the passenger A pillar cover, gently pry it off starting from the top next to the headliner. Several plastic body buttons hold it in place. About 1/2 way down on the inside, there's a separate plastic retaining clip that you must rotate 90 degrees in order to release its lock on the metal framing. This clip is important as it keeps the A frame cover from flying off during the air bag deployment. When you re-install the cover, be sure you rotate it 90 degrees again to re-lock it. I have used a needle nose pliers to reach it for the rotations.
    Now that the airbag and innards are exposed, you can see the best path to add your wiring to. If you want a lead that becomes "hot" only when the headlights are on, use the green lead from the lower glovebox LED which is powered by the headlight switch. You will need to carefully trim away some of the plastic flexible conduit from the LED to gain access to the green wire. The white wire is the ground lead. Good luck.
  9. cmrj
    cmrj Junior Member
    34
    Boise, Idaho
  10. lenjack
    804
    114
    Pennsylvania USA
    I'm thinking of just running the wires to the under dash fuse box on the driver's side. Any reason that won't work. Did that on my '98 Camry.
  11. phoenixgreg
    1,157
    291
    66
    Phoenix
    The A frame cover removal process for the driver's side is the same as the passenger side. The reason I sent you down the passenger side is that the glove box LED is closer to that side. It would do a nice job of powering the auto-dim mirror only when the headlights are on.
  12. lenjack
    804
    114
    Pennsylvania USA
    Thanks very much. Much better than going to the fuse junction.
  13. phoenixgreg
    1,157
    291
    66
    Phoenix
    All you will need is a T-tap for the green lead on the LED and a ground lead should be available just screwing it to the roof (I think there are some bolts up there) inside that little panel forward of the sun-glass holder. You carefully pry it off with a small screwdriver and it too is held up there with a couple of plastic body buttons.
  14. lenjack
    804
    114
    Pennsylvania USA
    Just saw your next gen mfd design...WOW!! I want one yesterday!
  15. phoenixgreg
    1,157
    291
    66
    Phoenix
    Me too! I hope Toyota R&D is reading this forum.
  16. skylarii
    skylarii New Member
    34
    OR
    Lenjack
    Please tell me how your install went and any details and pixs.
    I just purchased a used dimmer with homelink that came from an '05 Prius and wondering how easy it is to install on my 2011. I have read other people taking their old one from their Prius and having it installed on their gen III model II.
    Seems like a lot of work on the headliner and a-pillar but not really too bad. What gets me is if there is an easier way since I just saw a youtube vid about a 30 sec install of one of these dimmer mirrors onto a new Camry. The guy did it fast but the connections only needed to go into an existing harness in the headliner behind the map light. No such luck in our case though??
    Thanks !
  17. skylarii
    skylarii New Member
    34
    OR
    This install went well and the part procurement was a little rough but the seller did a great job to source the missing parts like the wire harness and the cable cover.
    The only thing I will add is that I would forgo using the console area to get to any power or ground since pulling that console down adds the risk of making for a poor fit when you put the console back in. Mine ended up having a gap so you could see wiring inside. I tried to bend the mounting point back up but it just did not help. I tried some different snap/clips that were shorter but that did not help either. Even tried hot melt glue to help glue the original mounting points (rubber ball spaces with adhesive) back against the roof but that did not seem to really hold it in place. I finally just added the glue to rear tabs on the console so that they had enough dried glue on it to make for a tight grip onto the headliner. This helped to lessen that gap but still did not look like it was "like factory". Some might be lucky to pull the console once and get no space/gap. But if I had it to do over again, I would skip wiring anything up in the console area and just take the front cover off that is seated close to the window and just run the wires down from there. I did not care about the power being on when the car was off so I just connected both Red and Black wires from my mirror together and in turn tapped into the outside mirror control harness gray wire (Acc power).
    Works great and I did have the issue with the sensor line of sight problem as noted in many places in PC. I did the simple recommended fix and flipped the mirror up side down. Some say the mirror cannot flip that way on their cars and mine seemed to have that problem as well. Then I realized that you have to gently wiggle the mirror right to left little by little after you flip it so it can then position it high enough so you can see the rear window through it. Be careful with the cabling as you flip the mirror so you don't overly strain the wiring or damage it. You can certainly disconnect the harness from the mirror before making any adjustments.
    This install was well worth it and I give it a hardy "Recommend!"
