Installing Dash Cams in a 2015 Prius C I-tech
Discussion in 'Prius c Accessories and Modifications' started by Nakaleen, Jul 2, 2015.
  1. Nakaleen
    Nakaleen New Member
    Victoria, Australia
    2015 Prius c
    I have just got a new Prius C 2015 I-tech (my first Prius, plus my first new car in total).
    I got 2 Mini-806 Dash cams I wish to install one in front and back. I have also got a 5 and 6 meter usb cable and a dual usb socket charger (2.1a) to power them.
    The thing is that I want to run the cables from the front to the side. But I am not to sure on how to remove the sides as the manual shows that the side curtains safety bags are in the same place and I don't want to do anything to damage them or anything alse. I found a YouTube video of a Prius 2012 install but that doesn't have the same side curtains safety bags.
    Is it safe to remove the side panels (between the windshield and the door)
    Basically I wont to know is it safe to take off the inside side panels.... Yes or No... Yes it is ok, No don't do it....?
  2. Masterloc
    Masterloc Junior Member
    53
    New York
    2015 Prius c
    I have the 2015 Prius C3
    You're referring to the A-pillar.
    I just recently did it while installing the autodim homelink rearview mirror.
    All I can say is, the Prius C is the easiest car to disassemble. everything is pretty much plastic clip.
    You'll need a needle-nose plier to remove the a-pillar cover.
    first, I recomment to remove the rubber door jam, it makes removing the a-pillar panel much much easier. Afterward just pry the plastic panel out, you can use your hand if you want. It WILL stop you from completely remove the panel. there's 2 clips. one near the top and one around the center. Once the panel is loose, you'll need to use a needle-nose plier to rotate the top clip 90 degrees. That clip acts like a lock, and you need to unlock it by rotating it 90 degrees. Afterward, the whole panel just pops out and you can wire it however you want. That's it.
