installing wheelskins today - question?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by pmanza, Feb 19, 2008.
  1. pmanza
    pmanza Fernsmom
    123
    Sacramento
    Hi everyone
    I am going to be sewing on my wheelskin today but I have a question. I know "tight is right" but with the leather just sitting on the steering wheel, I have about a 1/4 inch gap between the leather edges. I just can't imagine the leather stretching enough to meet in the middle. Is this the way it was for all of you? Will it come together in the middle? Or did I maybe get one that wasn't measured quite right?:confused:
    Thanks for your help, I got a charcoal grey top and bottom, green sides (my son ordered it for me). The green is a very nice suble color. If I had known how nice it was I would have wanted green top and bottom, grey on sides. Oh well. Will try to post pic's when done if I can figure it out.:confused:
    Fernsmom
  2. Steamboatsig
    Steamboatsig Member
    337
    Los Angeles
    2013 Prius Plug-in
    I wonder if you are supposed to install, wait for the leather to stretch, then readjust after a day or two.
    Another thing you can do is slightly warm and wet the leather then install it. Then it should shrink tight.
    But I am just speaking out of my a$$ because I haven't installed one myself. :rolleyes:
    Keep us updated because I am considering buying one too.
  3. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
  4. Bobbyb
    Bobbyb bobbyb
    62
    Long Island
    Use a hair dryer but not to much to give you a little help..
  5. pmanza
    pmanza Fernsmom
    123
    Sacramento
    Thanks Boo and Bobby
    Boo - I did read that thread and have my mirror and needlenose pliers with me (I plan on doing this at lunch at work - can't seem to get time at home!!!).
    Bobby - guess if it doesn't go tight, I will have to wait till I get home and can try the hairdryer trick, that is a good idea.
    Thanks again
    Fernsmom;)
  6. david81
    david81 New Member
    62
    NE Ohio
    Just installed mine a few days ago. It will certainly stretch enough to meet in the middle. I had planned on using a steamer when finished to really tighten it up, but now that it's on, I don't see the need. It did take quite a while, but it was well worth it.
    One word of caution from my install. I took the "tight is right" to the extreme and used a pair of pliers to really get it tight all the way around. Worked great until about 2/3rds of the way around....snap. Luckily it was near a spoke and I was able to hide the knot that I had to tie in the thread. Also broke the included needle with those same pliers. Lesson learned.
    All in all, it was a very easy install and worth the time it took.
    Oh, and in regards to temp...I was in my unheated garage in cold NE Ohio. No problems here except cold fingers.
    Good luck,
    David
  7. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    I did mine in two passes. The first time it wasn't as tight, as I didn't know how taut I could make it. After a couple of days the skin stretched a bit and I went back to redo the whole thing. It was much easier the second time around, and I also was able to make it look nicer.
    Short answer is the fit should be snug and there should be no gap.
  8. Godiva
    Godiva AmeriKan Citizen
    10,339
    Try a crochet hook.
    Yes, you'll need to allow the leather to relax. A warm car is good.
    I laced mine for a few holes, then went back and tightened, then repeated. Then went back and tightened the whole lot. I kept going back and retightening all of the lacing until I got the leather to touch around the entire wheel sans spokes.
    If I had to do it again I'd use two needles and do a herringbone stitch, like on a baseball, rather than the whip stitch they recommend.
    But try the crochet hook. It makes it easy to grab the thread and tighten.
  9. pmanza
    pmanza Fernsmom
    123
    Sacramento
    Godiva
    great idea! off to michaels I go! I assume a fairly small one? Didn't get to do the job at lunch today, grrr.
    Fernsmom
  10. Godiva
    10,339
    Not too small. I don't remember what size I used. Probably something around a "G". One size either way won't hurt. Try to get a metal, not a plastic hook.
  11. Pinan
    Pinan Member
    173
    Murrieta, CA
    It will definitely stretch, and you want it to. That way it's good and tight so it won't slide around. Take your time and use pliers to pull the needle through or your hands/fingers will get mighty tired/sore. Also. Unravel the thread fully before you start. It likes to kink as you go, so keep your eye on it. Lining up the stitches in a straight line is difficult, but if you take your time and keep it lined up as you go you can do well. I've done 30 or so of these and I got better every time. Takes me about and 30-45 min....taking my time.
    Before you start, flip it inside out and remove all of the little leather punch-outs. If you don't, you'll end up with annoying little bumps everywhere. ;)
  12. BubbaVO
    BubbaVO New Member
    53
    Philly
    I just did mine this weekend.
    Follow the directions. They're pretty good.
    Somethings that the directions don't cover... Stick the needle in the holes in advance of sewing as that will help you find them later. As you're going around, make sure that the seam is located where you want it to be when you assume your driving position. Use a headlamp to help find the holes on the back of the steering wheel. I ended up using my hands to tighten the string and it took more than an hour. Then again, I don't have a 1/4 inch gap anywhere. Take your time and do it right. Get some band-aids to cover the last joint of your index finger and pinky - that's where I cut up my hands a bit. Because the string does kink up, unroll the string and stretch it out before hand; and remember to occassionally unwind the string.
    I've gotten rave reviews from the wife and co-workers. It's a quality product and worth it. Good luck w/yours.
  13. pmanza
    pmanza Fernsmom
    123
    Sacramento
    thanks again everyone, hopefully I can start stitching today. I did pre-punch the holes and get rid of the little punch outs. Having trouble figuring out where I want my seam to go though. Don't want to see it, but also dont' want to feel it!
    BubbaVO - where did you get your sheepskins and how do you like them? Did you get them for the backseat also?
    Fernsmom;)
  14. Trevor
    Trevor Member
    352
    Staten Island, NY
    As others have said, it will stretch if you pull hard enough. The hard part for me was pulling hard enough without hurting my hands. I was in too much of a hurry to get my new toy installed so I didn't look for gloves or go shopping for a crochet hook. My hands ached for days afterwards. I put a sock on my hand halfway the procedure to lessen the string digging into my hands/fingers and that eased the strain a bit.
  15. takeshi
    takeshi New Member
    Houston
    The baseball stitch is a lot nicer. It's easier to use if you have a second needle and second cord.
  16. zenMachine
    3,355
    300
    Totally concur about the herringbone stitch. If/when I do my next one I'll be sure to do it that way.
  17. pmanza
    pmanza Fernsmom
    123
    Sacramento
    Well I got it on! Haven't tied it off yet though, figured I'd let it set awhile and then try to tighten one more time. Looks Great!
    Godiva I was stupid and bought an "E" crochet hook, looked like it would be easier to grab the thread with. Maybe, but it was also thin enough to bend! So I ended up using the needlenose pliers to tighten with.
    Got it together most of the way around, just have a couple little spots to try and fix. Funny thing though, I got two-tone, and the different color leathers have different properties. The Charcoal is smoother (very little grain) and much stiffer, the green is softer, has more grain, and was more elastic, easier to tighten. If I could have seen/felt the leathers, I would have ordered solid green. But, the texture will vary from hide to hide so...
    thanks everyone for the great advice on how to best get this nice upgrade on.
    Fernsmom:D
  18. edthefox5
    edthefox5 Senior Member
    10,096
    4,829
    Clearwater, Florida
