Interior lights don't come on when I'm near the car
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ES44AC, Nov 3, 2013.
  1. ES44AC
    ES44AC C.A.U.S
    319
    77
    They used too but now they don't. They do come on if I lock the car and then use the fob to manually unlock the car or touch the door handle.
    I have tried my other fob and it still won't work.
    It was always fine until today, other than a fuse is there something that accidentally got turned off?
    Is a trip to my stealer in my future?
    Thanks to everyone in advance,
    ES44AC
  2. xliderider
    xliderider Senior Member
    8,029
    3,206
    Honolulu, HI
    Maybe your fob battery is getting weak? The SKS fob batteries needed to be changed at 2 years on my Camry.
    SCH-I535
  3. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    The dome light only comes on automatically if the doors are locked. Are the doors locked?
  4. Alan Claver
    Alan Claver Junior Member
    79
    Central Pennsylvania
    This is a dealer changeable setting (or user if you have an interface and software). Perhaps the setting was changed due to computer error.
  5. ES44AC
    ES44AC C.A.U.S
    319
    77
    Yes I tried it with the doors locked and still no response to the SKS being near the car. I just find it hard to believe that both the fobs have low batteries one of the 2 I have was never used. I'll check with a voltmeter and see.
    Thanks
    ES44AC
  6. El Dobro
    El Dobro A Member
    7,071
    3,258
    Does the transmitter LED blink when you get near the car?
  7. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    os the interior light switch on the door position?
  8. ES44AC
    ES44AC C.A.U.S
    319
    77
    Believe it or now, its working now with the doors locked. The battery voltage is a bit under 3vdc So I will replace the battery and see what happens. But again, right now it's working as it did B 4. Don't ask me why! :D
    Thanks
  9. ES44AC
    ES44AC C.A.U.S
    319
    77
    Hi Spidey,
    yes it is that was the first thing I looked at.
    ES44AC
  10. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Great to hear it is working. Mine was doing odd things too and I replaced the battery... all is well.
