intermittent lock problems
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by sumguy, Feb 2, 2010.
  1. sumguy
    sumguy Junior Member
    93
    Ohio
    Yesterday was the 2nd time I've had a problem with the driver door lock. Only happened since its been cold and may be related to no-touch high pressure car wash. 1st time the door wouldn't shut. Manually unlocked it and used buttons but it kept bouncing open took a few minutes but it finally shut. Can't remember if that was a car wash day. Yesterday, washed car in morning and everything fine. Temps in 20's. After I got to work that night, the door wouldn't open - had to exit passenger side. Tried manually locking and unlocking and using buttons but nothing worked. Was fine in morning to go home.
  2. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
    So this happened after the car was washed and the temps are below freezing? And it's the door that will not shut/open right, not the actual lock itself? If that's right then it is simply water freezing keeping the door from opening/closing properly.
  3. sumguy
    93
    Ohio
    yeah. the weird thing was the door worked fine then 10 minutes later I'm at work and it wouldn't open.
