inverter and converter problem
Discussion in 'Gen 2 Prius Technical Discussion' started by statultra, Jul 28, 2006.
  1. statultra
    statultra uber-Senior Member
    798
    31
    Edison,NJ
    2001 Prius
    I was driving today then suddenly, the red triangle and check engine lights became lit on my 2001 Prius, the vehicle continued to drive normally. When i came to a stop and waited at a stop light the dashboard got dim as if my 12 volt system was down, then the 12v battery discharge light, so i started driving again and the discharge light went away, then i stopped the vehicle and i touched the inverter it was hot to touch, which i thought was unusual, the coolant levels were good too, i pulled the code P3130 Auxiliary Emissions control fuel air metering. I erased all the codes, and the triangle is gone, i left the vehicle to sit for 20 minutes , then restarted and proceeded on another journey and 5 minutes into the drive the same problem again.
    This led me to believe a cooling problem or something is going bad.
    The vehicle continues to drive normally, and this prius is under warranty i just dont know if i should take it yet until i know its a the hybrid powertrain problem. I think this is a potential inverter/ converter problem not sure.
    Also today was above 90 degree F here in jersey city
    What do you think?
  2. Bill Merchant
    Bill Merchant absit invidia
    4,096
    85
    If it's under warranty, what are you thinking? It may fix itself? Take it in! Maybe it just needs a coolant flush for better circulation to the inverter, but what ever, don't fry your car guessing what it may need.
  3. barbaram
    barbaram Active Member
    912
    70
    Trenton, NJ
    get thee to the dealer!
    the inverter is the heart of the system- no sense fooling around!
  4. statultra
    798
    31
    Edison,NJ
    2001 Prius
    i found out there was air in the coolant system, and managed to get rid of it on the hottest day here, so i topped it off, and its good as new now, althuogh im thinking i will need a new inverter, its still under warranty so once it happens again im bringing it in, i have low power output right about now, but this is my only car i have that is registered and insured, my 05 prius hybrid is awaiting salvage inspection.
