IPSWH . . . what?
Discussion in 'Environmental Discussion' started by Sufferin' Prius Envy, Aug 29, 2007.
  1. Sufferin' Prius Envy
    Sufferin' Prius Envy Platinum Member
    3,998
    BOY do I wish I had a sunny Southern exposure. :(
    [but no, not willing to give up the large shade trees ;) ]
    This is not your typical expensive solar water heater. Many of these systems are built with recycled components for just a few hundred dollars. The payback is just a few years, and they are non-polluting.
    INTEGRAL: It is used in conjunction with your current water heater - heating the water BEFORE it goes into your current water heater. 70% or more of yearly hot water demand is met just from this unit.
    PASSIVE: No moving parts. Turn on a hot water tap and preheated water flows from the IPSWH to the existing water heater.
    http://www.motherearthnews.com/DIY/1984-01...ter-Heater.aspx
    [caution: 9MB PDF]
    http://www.builditsolar.com/Projects/Water...ISPWH/IPSWH.pdf
    http://www.epsea.org/wtr.html
  2. dogfriend
    7,512
    1,188
    Carmichael, CA
    <div class='quotetop'>QUOTE(Sufferin' Prius Envy @ Aug 29 2007, 04:22 PM) [snapback]504021[/snapback]</div>
    Yeah, I have the same situation - we have a 90 ft high Sycamore + other trees that shade all of the southern facing parts of our roof.
    However, my brother-in-law has something like this in his house. They get most of the water heated by solar with a standard water heater for backup.
  3. galaxee
    galaxee mostly benevolent
    9,810
    468
    MD
    yep, that's about what our system is. works well too! i have switched a lot of our hot water consumption to the daytime and we rarely use the water heater.
    let me see if i can get a shot of what's on our roof...
  4. TimBikes
    TimBikes New Member
    2,492
    245
    WA
    This is great. Thanks for posting it. The commercial systems seem a bit pricey and overdone.
    <div class='quotetop'>QUOTE(galaxee @ Aug 29 2007, 08:38 PM) [snapback]504137[/snapback]</div>
    Did you build it yourself? Can you share any plans / info?
  5. galaxee
    9,810
    468
    MD
    ha, no, we're renters. we've got a standard panel of pipes up on the roof, but the concept is the same.
