Is EV really that useful? Also, is B fine to always use?
Discussion in 'Gen 3 Prius Technical Discussion' started by Skoorbmax, Mar 27, 2010.
  1. Skoorbmax
    Skoorbmax Senior Member
    2,641
    264
    Western NY
    EV mode I was playing with a bit but it seems that given its very short range AND the fact that the manual even says that if you use it too much it can in fact negatively impact mileage, I wonder if there is really much point to it; when does one normally use it? Without it, in bumper to bumper, the ICE often won't start anyway, even not in EV mode...
    Also for B which gives extra "engine braking", is there any reason in the world I can't have it on all the time? I kind of look at it like D like level 1 and B like level 2 of how aggressive the braking is. Do many people just always use B?
  2. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    EV is great for moving your car out of the garage onto the drive to wash it but that's about it. It's a play thing, a gimmick. It has limited use and if you do over use it and run the battery down, then the engine has to work harder to put that energy back - affecting mpg.
    The 'B' option is mainly for use on steep hills. I only use it on one particularly long hill near me, otherwise I don't bother.
  3. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
    EV mode is great when moving a car across a parking lot or other extremely short trip where there is no point to warming up the engine.
    B wastes energy with more engine braking, less regeneration than D. So long as gas mileage is not one of your goals, you can run it all the time. Most Prius owners value gas mileage.
    If you are on a downhill with more than 600 feet of vertical drop, the HV Battery will fully charge, so no more regen can happen. At that point D will have to use friction braking, while B can slow the decent with engine Braking.
    This downhill into Warsaw NY may be a good use of B. After the incline, there is a sharp turn under a bridge, you will want fresh brakes.
    Google Maps
  4. Skoorbmax
    2,641
    264
    Western NY
    Thanks. I thought EV was a gimmick but didn't want to offend anyone ;)
    I can see for something short to encourage no start of the engine it would be useful, though.
    "B wastes energy with more engine braking" Is it realy ICE engine breaking, though? I thought it was braking via more aggressive regen of battery?
  5. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
    Nope. No more aggressive charging is possible without damaging the battery. Here is Hobbit's detailed explanation, but it can be summarized by 'B stands for engine Braking'
    http://www.techno-fandom.org/~hobbit/cars/b-mode.html
  6. Tom183
    Tom183 New Member
    652
    65
    Maine
    That's good advice - normal regen is preferred most of the time, but for long hills it's better to use engine braking.
    I suppose the ideal would be to use regen braking while watching the battery - when it gets near full, flip into B.
  7. Tom183
    Tom183 New Member
    652
    65
    Maine
    Basically, B mode uses the "suction" of the engine to create drag on the wheels. It isn't burning gas, but it is wasting energy that could be captured by regen instead - provided you have somewhere to put it (i.e.: "space" in the battery)
    My question is:
    Why aren't the Prius electronics smart enough to switch into B mode automatically when the battery is full?
  8. hampdenwireless
    hampdenwireless Active Member
    1,104
    86
    Baltimore MD
    That is a great idea. That would save brake pads and in rare conditions make the car safer by having cooler brakes! (such as times when the user SHOULD have manually selected B mode on a long downhill) I don't think Toyota is ready to add more complexity to its software though.
  9. sgm0815
    sgm0815 Junior Member
    Austria
    Depending on the hill, you can try to use the cruise control.
    Cruise control will try to decelerate using regenerative braking - but when the batteries are full or if braking power is not sufficent ICE engine brake kicks in as well. I did not use B - just D.
    Martin (from Austria where there are a lot of mountains)
  10. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
  11. Skoorbmax
    2,641
    264
    Western NY
    Thanks all this answers it perfectly.
  12. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    With regard to
    actually, it more or less does. Once you're topped, the engine is
    brought to spinning anyway [generally, with no fuel injected].
    Then, if you flip to "B", a lot *more* spinning happens and that's
    when you're sailing down the hill with the "jet roar" coming from
    under the hood.
    What I generally do is use "B" as needed if on a long downhill to
    try and balance regen vs. brake use, and then try to stay mostly
    in "D" once the battery is topped [and the engine is spinning
    anyway] for the rest of the run, unless I *really* need to take
    a load off the brakes and I'm at fairly low speed already. It
    takes a little predictive thinking about how long and steep the
    downhill is going to be. This is why mountain driving is such
    a blast; I refer to it as the "regen game". The real challenge
    is to try being close to *empty* as you crest the hill, but that's
    almost impossible if there's traffic behind you.
    _H*
  13. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    The ideal way to use B mode is to shift into B early on a downhill, but only on a downhill where regeneration will max out. The problem with that, of course, is that you need to know the characteristics of the hill and battery SOC in advance, so most of the time you can only guess, unless it's a hill you often drive.
    If you wait to shift into B, it's pretty much the same as letting the Prius do it automatically.
    Some drivers also use B mode on long down grades for simplicity. It makes it easy to control speed with just the gas.
    Tom
    2 people like this.
  14. macman408
    macman408 Electron Guidance Counselor
    1,179
    367
    What makes you say that? I'd have assumed that doing that versus shifting to B late would be roughly equivalent: Shifting early, you might charge the battery more slowly on the way down (Maybe? I have yet to use B in my 2-week-old Prius...), but in both cases, you'd start with the same charge, end with a full battery, and use no gas on the way down (though if you're in B most of the way, the engine will be using compression braking for longer).
  15. dogfriend
    7,512
    1,188
    Carmichael, CA
    It actually does, the occasions where this might happen are pretty rare, but I have induced it by staying in D down a long steep downhill - once the battery gets fully (80 percent) charged the rpms will rise on regen coasting and braking. Shifting into B maximizes this effect.
    You can also think of B = bad mileage, if you use it when you don't need it. :madgrin:
  16. qbee42
    18,058
    3,076
    Northern Michigan
    You are forgetting friction braking. You are correct that both scenarios end up with a full battery, and the gas consumption is the same, assuming you actually needed to brake. But in the first case the friction brakes take a beating.
    As you brake down a hill the Prius uses regeneration to capture the braking energy that would otherwise be wasted. When the HV battery gets charged up to the high limit, the Prius stops regeneration and switches to engine and friction braking. This is equivalent to B mode, except the HV battery is already at the high limit.
    When you shift to B mode, the Prius immediately starts using engine braking along with regeneration. This pushes back the point where friction braking must be used, saving wear on the friction brakes and helping to eliminate brake fade.
    It takes a pretty steep hill before any of this makes any difference, but on a long steep hill shifting to B mode early will help save the friction brakes.
    Tom
  17. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    This thread raises a couple of interesting questions for a circumstance that I have yet to encounter.
    1. When your traction battery is fully charged (I haven't encountered this yet), does the brake regen no longer engage when braking, or does regnen still work for braking, with the recaptured electrical energy sacrificed as heat?
    2. Is the feel of the brakes different when the traction battery is fully charged?
    Thank you
  18. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    I can confirm all the above. I use B very sparingly and mainly on steep declines, in the same way I would shift to a lower gear on the manual gearshift of my previous car. I can also confirm that the Prius will start engine braking even in D when battery is full (it happened to me on the highway once).
    The regen drag is "strong" enough to be used in town without the need to brake the whole time or use B (my father has a Honda Jazz/Fit with CVT, and you need to brake the whole time or shift from D to L to get some engine braking).
    The EV mode is useful, after 9000km driving, only when wanting to move the car from a cold start from A to B (e.g. between parking lots, as mentioned above to wash the car on the driveway, etc.). I see it perfect in the US to go from one store to another between parking lots of huge shopping malls (often spread between 2 or more roads): in summer the engine, after a longer stop, might still not do the warm-up procedure, but in winter, if battery is full enough, you can avoid it altogether and move the car with 0 fuel consumption.
    Other than that, with the capacity of the battery we currently have, EV is mostly a marketing gig. You can go "EV" also without selecting it if you are light on the gas pedal, drive slow and have enough charge (more than 2 bars).
    EV will not engage, if you don't have at least 4 bars, if I remember correctly.
  19. Tom183
    Tom183 New Member
    652
    65
    Maine
    So the Prius does automatically use engine braking when the HV battery is "full".
    That tells me not to bother with B mode unless I know a hill will definitely max out the battery. (pretty much what the manual says in far less detail)
  20. qbee42
    18,058
    3,076
    Northern Michigan
    In the technical sense regenerative braking stops when the HV battery hits the high limit. MG2 is still used for engine braking, which is really a form of dynamic braking. Instead of electricity going from MG2 to the HV battery, the electricity goes from MG2 to MG1 and is used to spin the ICE as a big air pump. The ICE really revs up to a high speed, but it is not burning fuel.
    If you are familiar with your car you can feel a difference when regeneration stops. Likewise you can hear the ICE start spinning.
    Correct. There is no reason to use B mode unless the HV battery will max out, with two possible exceptions:
    1) On a very, very steep hill you may want a lot of braking. Using B mode allows for regeneration and engine braking at the same time, instead of one at a time.
    2) Some people like B mode for a feeling of improved control when descending a hill. Mostly this is because it is easy to control speed in B mode: lift your foot off the gas, things slow down; press on the gas, things to faster.
    Tom
