Is Prius for me?
Discussion in 'Gen 2 Prius Main Forum' started by PRwanting, Jul 16, 2011.
  1. PRwanting
    PRwanting Junior Member
    48
    Boston, MA
    Hello,
    I'm considering about buying a PRIUS, but before really buying one I would like to know about few things since I've heard a lot of myths about Pirus.
    Anyway, right now I own a 1999 Toyota Camry on it's 175K miles and thinking about trading it in for a used Prius at local Toyota dealership. I'm looking at a gen 2 with around 70-90k miles. Thanks for the help in advance.
    1. And how RELIABLE commuter car is it? I'll mostly use it to go to my work (about 4.0 miles back and forth from my house) and chores around the city. Now I don't have a lot of money; actually need to save more in order to afford my kid's college education. My question is how reliable is Prius? Is it reliable enough to go atleast 150k? My camry hasn't had a single issue except for exhaust pipe but that was only $120. Is Prius that reliable?
    2. Is it good enough to drive in the snow/ can I drive without snow tires since I live in Mass?
    3. What are the normal failures to expect on a 100k Prius?
    4. what should I look out for while buying used?
    5. Is there a particular year of the gen 2 that is better
    6. Is summer the best time to buy one or should I wait till winter?
    7. Which model yr has the inverter Pump issue? Is there a recall for that?
  2. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
  3. cproaudio
    cproaudio Speedlock Overrider
    2,401
    760
    CA
    4 mile trip would probably get you about 35-40mpg. Lower in the winter time. The Prius get its best mpg when the engine is warmed up. Since the engine shuts down when you come to a complete stop, it takes longer distance to warm up.
  4. jdenenberg
    jdenenberg EE Professor
    3,910
    1,908
    Trumbull, CT
    2020 Prius
    LE AWD-e
    2. If you use the right tires, snow/ice is no problem. I suggest Nokian WRg2 tires from Finland. I use them year around.
    JeffD
  5. PRwanting
    48
    Boston, MA
    Thanks everyone for your replies. Well it's 4miles from work and few miles here and there. So I should've said it's around 10miles everyday. Right now I'm getting about 19-21MPG with my camry (even lower in the winter). So mid30 or 40 is more than enough for me.
    So I read a few Priuses turn themselves off when they hit a bump or pot hole. Is that true? Where I live, the road isn't perfect. Every few ft. there r bumps and pot holes on the road.
  6. PRwanting
    48
    Boston, MA
  7. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
    I've heard a lot of myths but I have yet to hear that they turn themselves off when they hit a bump or pot hole. If that was the case with mine here in Michigan, I would never get anywhere!
  8. cproaudio
    2,401
    760
    CA
    It has to be driven consecutively not 2 miles here then 3 miles there. Once you stopped, the engine cools down and you have to start over. So, 2 miles here gets you 30mpg, 3 miles there gets you 33mpg. Soon you'll end up with 300 mile tank instead of 500 mile tank like everyone else. In your situation, you'll benefit from plugin hybrid instead of regular hybrid.
    Also, com'n seriously? hit a bump and it shuts off? where did you hear that from? some guy or from a national news? Do you think they would let Toyota get away if the Prius shuts off when it hits a bump? The media would eat that up, law suits would pile up. The only bump related defect related to the Prius is .1 second of loss of brakes. There's already a discussion about that and there's already a fix for that.
    Prius is just like any other car. There are happy owners and there are lemons. Almost all the owners are happy with it. Still, there are a few owners who're not happy with what they got.
    If you're serious about buying one, I'm sure the dealer will let you test drive one. I'm not too keen on Gen II. All I know is that 04 and 05's ODO is limited to 299,999 miles. 06 and up fixed that. 04 and 05 use low res screen while 06 and up use high res screen.
  9. Tideland Prius
    16,402
    I was gonna say keep the Camry until you mentioned 19-20mpg in the summer since the Camry is fairly reliable and you can go another 175k miles on that car without much issues.
    1. The Gen 2s have been fairly reliable compared to the Gen 1s (not that the Gen 1s were lemons). The hybrid system (including the battery) is warranted for 8 years/100,000 miles or 10 years/150,000 miles if it's registered in a CARB state.
    2. I would strongly recommend winter tyres. The difference in grip is very noticeable. The Gen 2s also have a very aggressive traction control (it's "fixed" i.e. made less aggressive for the 3rd Gen) so winter tyres will help alleviate the problem
    3. Not sure. There hasn't been a string of problems, just isolated problems here and there like any other reliable car. Maybe check to see if the coolant has been changed and the transaxle fluid
    4. Not really but do check that the brakes are in good working order (they're rarely used since the elec. motor does most of the work so make sure the brakes aren't rusted or any other issues associated with a car driven in the northern states through winter).
    5. The 2nd Gen was updated in 2006. It brought a few things that may interest you such as better dashboard material, occupant detection for the front passenger airbag, AUX input jack for the audio system (JBL) and an available backup camera w/ higher resolution screen and updated graphics. Leather was also made available in later years. For 2007, side airbags and side curtain airbags were made standard so if you buy a 2006, you might want to check if safety's your top priority.
  10. The Critic
    The Critic Resident Critic
    3,193
    2,326
    CA
    1) Reliability is pretty average IMO, from my experience on working on my friend's Gen II. The failures are very predictable and repair costs are comparable to your Camry.
    2) I would get snow tires, but then again I don't have snow in my area.
    3) Engine water pump ($400-$500), struts ($800-$1000), inverter water pump ($400-$600, not sure how well the updated version holds up), left front axle seal ($300-$500), frequent HID bulb replacement ($50/bulb) and MFD screen ($400-$600 for used one from eBay). Don't let those scare you away, as not every Prius will have these issues, but these are the common issues that you may see on a < 100k mile Prius.
    4) See if any of the issues listed in #3 have been corrected.
    5) 07 and newer, for the safety equipment reasons that others have mentioned. Reliability seems to be about the same for most Gen II years.
    6) Hard to say, but the market for fuel efficient cars is still tight right now. Prices are fairly high.
    7) I believe it's 04-07. It is a service campaign, not a recall.
  11. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Yep. Never heard that myth before. Perhaps the OP's confusing it with Ford issues prompt fix for Fusion Hybrid brakes (which reared its head during the 3rd gen Prius SSC-A0B brake firmware "uproar").
  12. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    Even at $5/gallon for gas, a car getting 20mpg compared to a Prius getting 50mpg (which could be a stretch given your short commutes) would take you 6666 2/3 miles before it'd cost you an extra $1000 of gas.
    Given that gas isn't $5/gallon, you've mentioned money's tight and you're only doing 10 miles per day I'd say keep running your Camry, particularly because efficient used cars are expensive right now.
    Consider your position again in 6 months or a year. Japanese production will be back to normal, there will be plenty of the newer efficient compacts and subcompacts out there to help suppress used car prices and a resolution in Libya would help relieve some of the pressure on NE gas prices.
    But, keep an eye on those used car ads, since if your older car starts giving you trouble the maintenance costs can really shift the balance.
  13. FreydNot
    FreydNot Member
    214
    37
    Seattle, WA USA
    Maybe they were referring to the overly aggressive ABS system which is known to briefly "STOP" applying breaking force to the wheels when you hit a pothole.
  14. gscully
    gscully Junior Member
    22
    Long Island, NY
    that happens to me all the time Freyd. somewhat annoying.
  15. wmcbrine
    wmcbrine Junior Member
    56
    Laurel, MD
    I drive mostly very short trips, and my mileage sucks compared to others here, but it's still twice as good as any car I had before. Now, with the amount of driving I do, maybe I'm not saving enough gas to justify having bought a Prius, from a strictly monetary point of view; but for me, that's not the only or most important reason to have one.
    The Prius is near the top of the reliability ratings in Consumer Reports, IIRC.
    No, it doesn't turn itself off when it hits a bump, or at any other time. It does turn the engine off frequently, though, which could seem freaky if you're used to that meaning "stall". Personally, I enjoy the silence. :)
