Is that noise a strut, bushing, shock or what???
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jrod81, Apr 14, 2012.
  1. jrod81
    jrod81 Member
    161
    Fayetteville, AR
    Just bought an 06 with 79k miles... overall in great condition, but when I pull into a parking lot or my driveway or anywhere that has a bump there is a noise... sounds maybe like a strut or shock... is this a common noise as we near 100k miles???
  2. Patrick Wong
    18,200
    6,490
    With 97K miles logged, it is quite likely that your struts/shocks need to be replaced.
    It is also possible that a front sway bar bushing is worn, allowing the sway bar to thump against the body as you go over a bump.
  3. cnschult
    cnschult Active Member
    772
    97
    Michigan
  4. jrod81
    jrod81 Member
    161
    Fayetteville, AR
    thanks cnschult
  5. dhanson865
    dhanson865 Expert and Devil's advocate
    851
    188
    TN, USA
    I've got an 05 with a few less miles on it but I think the rear right suspension was worn out two years ago (slight vibration from right rear at highway speeds that didn't go away when buying new tires or rotating tires).
    What is on the rear:
    Shocks
    springs
    Struts
    All 3, some combination of 2?
    Only one of them but all 3 names are used to describe the one set of things that gets replaced?
  6. Patrick Wong
    18,200
    6,490
    Each side of the rear suspension has a shock surrounded by a coil spring. The coil spring is typically reused unless your car has logged so many miles that the car is sagging - in that case the coil springs would be replaced.
    The difference between a strut and a shock is that the former can support a sideways load not along the axis of the strut's compression. Therefore the strut is substantially more robust in its construction.
  7. dhanson865
    851
    188
    TN, USA
    No sag that I notice and I'm not looking to lower the car so I'll keep the springs.
    So I should just be looking at shocks, not struts?
  8. Patrick Wong
    18,200
    6,490
    If you wish to replace the rear shock-absorbing parts only, then you would just purchase and replace the two rear shocks. Optionally you could replace the rubber insulator rings that fit between the shocks and the bottom of the coil springs.
    If you also wish to replace the front shock-absorbing parts, then you would need to purchase and replace the front struts as well as the pleated rubber covers that keep dirt out, the top strut bearings, and the rubber insulator rings between the struts and coil spring bottoms.
