Is There A Quick, Single-Push-of-a-Button Method to Turn Off the MFD?
Discussion in 'Gen 2 Prius Main Forum' started by Kizzy, Dec 30, 2007.
  1. Kizzy
    Kizzy Member
    110
    Los Angeles
    Sometimes while I'm driving I'll decide to turn off the MFD. I know that it can be turned off by pressing the Display button, then selecting "Screen Off".
    Just curious though...is there a faster way, requiring only the push of a button, where I don't have to divert my attention from the road for quite so long? For example, holding down the Display button for three seconds? Something like that? Anyone know of a documented (or undocumented) way of turning off the screen with a single button push, regardless of which screen is presently showing on the MFD?
  2. Tideland Prius
    16,402
    Push the voice button. After the beep say "Screen Off"
    That's one button right ;)
  3. Kizzy
    Kizzy Member
    110
    Los Angeles
    Good suggestion. That would work, if only my Package 2 had the voice option. :)
  4. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    Personally, I use the [Display] => [OFF] method you described.
    Since the two buttons are very near each other, it's relatively simple.
  5. slair
    slair Ubër Senior Member
    404
    Lafayette, IN
    Press the big button right in the middle of the screen as hard as you can with your fist.
    It'll defiantly turn off, but no guarantee on how to get it to turn back on. :p
  6. Marvinh
    Marvinh Marvin
    190
    NY - Long Island
    Tony - Here's a question. It should be obvious but I never thought about it before seeing this thread. I'm almost afraid to ask :rolleyes:, but here goes:
    How do you put the display back on once you shut it off?
    Thanks, Marvin
  7. Tideland Prius
    16,402
    ohh :(
  8. hschuck
    hschuck Member
    385
    bay city, ca
    The display is turned back on by pressing any button on the bezel or the steering wheel that normally causes the display to change screens with the exception of the display button.
    Or if you have voice control 'display on' will work.
