Is there any safe way to attempt to plug in when you're not at a dedicated charging station?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by DCDave, Aug 18, 2012.
  1. DCDave
    DCDave Junior Member
    31
    Washington DC
    My friends don't have dedicated power lines running to their parking areas like we PiP owners do - but they do have grounded outlets nearby. Similarly, my employer says I could use the three-prong outlets in the parking garage if I could do so safely. Is there any way to protect their electrical systems (and the PiP) and test the ability to charge up using these 120v outlets? For example, would a GFCI adapter or power strip/circuit breaker or some other device be of any use (and, if so, what sort of rating would it require)? Or, unfortunately, is there NO safe way to attempt to use an electrical system that one is not intimately, totally familiar with? I'm guessing the answer is no, there's no safe way - but I thought I'd ask!
  2. chesleyn
    chesleyn Active Member
    596
    158
    Los Angeles
    The EVSE already has a built in GFCI as far as I am aware.
  3. Jimbo69ny
    Jimbo69ny Active Member
    712
    107
    Ithaca, NY
    plug it in. Im sure you will be fine.
  4. ultraturtle
    108
    81
    Peachtree City, GA
    Perhaps the better way to ask this question is:
    Has anyone, in the entire history of all of us PiP owners mooching a $.30 charge (maximum - assuming a 3 hour visit) from a friend, in-law, business, or other aquaintance ever blown a fuse or circuit breaker?
    My guess is the answer is a deafeningly silent "No".
    One caveat to my most recent post. The Plug-In Prius will only use a maximum of 12 amps of any (typically) 15 amp circuit, meaning that as many as 3 100W light bulbs could be operating on the same circuit at the time you plug in the PiP.
    A problem arises should one turn on even a single 100W incandescent bulb while the PiP is charging. Incandescent bulbs can demand nearly 10 times thier operating amperage for a fraction of a second as thier filament heats up - i.e. more than 8 amps, which (unless you have a slow blow fuse, or modern CB) could very well trip a breaker or blow a fuse.
    I'll adjust my previous guess to account for one or two instances of heavily loaded circuits, or large upstart loads being introduced after the PiP gets plugged in.
  5. Jimbo69ny
    712
    107
    Ithaca, NY
    I moved into an apartment complex that was built in the 70's. I park my car in a garage there. The garage building has something like 20 private garages in it. Each has one light bulb with an outlet. I was told that the whole building was on one 15 amp breaker. THere are other tenants running chest freezers and I have yet to blow a fuse. I was really worried about it but its not an issue.
  6. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
    Yes, I've tripped breakers at a family members hours and two hotels I stayed at trying to charge lol.
    But for the OPs purpose, it did what it should have and tripped the breaker. A simple reset is all that was needed. I wouldn't worry much about 'not doing it safely'.
  7. ultraturtle
    108
    81
    Peachtree City, GA
    Dammit, that's three instances, and I only accounted for one or two.
    Oh well.
  8. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
    haha, actually I messed up, it's 4. 2 family members homes... But one was an aunt in PA where the circuit into the garage was WAY underpowered, or at least I found out after while resetting it. It was a damn 10amp breaker! urgh...
  9. bisco
    50,825
    wow, never even seen a 10 amp breaker in 40 years of diy electric work.
  10. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    An outside outlet, or garage outlet, for that matter, should be GFCI protected according to US Electrical code. It should also be marked so. But you might want to check to make sure. Given that, it should be as safe as anything else you do with electricity, outside.
    [If you are using strange outlets frequently, you could purchase a circuit tester with a GFCI test button (around $5). This will ensure that the outlet is properly wired and protected. Just make sure you know where the reset is first!]
  11. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
    "Should be" is the relevant part of that quote. My house was built in 1949 and lacks grounds at all, let alone GFCI. Oddly, I have eight 220 outlets in my garage, two of them 3 phase. It is a crying shame I do not have a plug in car.
  12. chesleyn
    596
    158
    Los Angeles
    had same problem here. My house was built in 1950. Upgraded the panel and grounded circuits now. Made the outside gfci much easier.
  13. DLee
    DLee Junior Member
    81
    I just installed 4 of them. They are hard to find!
  14. DLee
    DLee Junior Member
    81
    You should install GFIs, even if you do not have a ground. A GFI looks for a difference between line current and neutral current. The ground is not involved. It is just there to provicde a connection for safety grounded equipment.
    The NEC lists residential safety levels: #1 is a GFI with ground. #2 is a GFI without ground, and #3 is an outlet without GFI but grounded, and #4 is an outlet without GFI or ground.
    When a GFI is installed without ground is installed, it must be marked as no ground service. Most GFIs come with a sticker to meet this requirement.
  15. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    I was charging an iMiev on a standard switched socket by my front door, the switch melted in the "on" position, but nothing tripped in my consumer unit. I'd been using the same socket for charging my PHEV for months before that.
  16. gallde
    gallde Active Member
    238
    130
    Tarrytown, NY
    I plug into a heavy-duty extension cord on a dedicated circuit at home, and into a parking-lot lamp-post outlet (with permission) at work. A couple times a co-worker with an electric Focus plugged into the same lamp-post circuit and popped the breaker inside the facility, but no harm. We just coordinate which posts we plug into!
    I time my charge at home (starts at 5am), but I don't bother to set the timer at work, and charge right away. So, I charge fully by noon and don't leave for about 6 hours. Anyone have a take on how much this strains the battery, or whether I will run into warranty problems by doing it?
  17. bisco
    50,825
    i'm not sure if there is a known answer for this. it's long term debilitation of the battery. how long and how much? if it were me, i would use the timer unless impossible to do so. climate also matters. full charge in hot weather is worse than cool. i don't think it affects warranty, because they are not going to warranty the battery for reduced range.
  18. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    Our house was built in 1963. When we moved in in 1999, it still had the original 60-amp fuse box and no 240V service. We ended up doing a complete panel replacement, adding 240V service, grounding as many outlets as we could, putting in GFCI's where required, and cleaning up the crappy wiring they had run in the garage for various "improvements" they had done.
