is there any way to tell packages apart by pictures?
Discussion in 'Gen 2 Prius Main Forum' started by thedutchtouch, Dec 4, 2008.
  1. thedutchtouch
    thedutchtouch prius is my SUV
    181
    Baltimore MD
    the prius in question is a 2006. i'm pretty sure it's a package 4 or lower, due to the lack of leather and what i think are the halogen headlights.
    any other interior clues to look for?
    [​IMG][​IMG][​IMG][​IMG][​IMG]
  2. thedutchtouch
    181
    Baltimore MD
    aha i found the vin VIN: JTDKB22U867530652
    Stock ID: 8322A
  3. Ct. Ken V
    Ct. Ken V Active Member
    535
    57
    Bolton,CT
    dutchtouch,
    Well, you sure don't have the leather (pictures 3 & 4) or the nav system (no more than 4 pushbuttons around the MFD screen in pictures 1 & 5), so you're right that it is a pkg 4 or lower. And you definitely do have the halogen headlights since I don't see any fog lights in the 2nd picture.
    Also, in the 1st picture I see the fob in the dash slot & in the 2nd picture no little black square button on the driver's door handle, so I'm guessing you don't have the SS/SE (also known as SKS).
    What is missing from the interior pictures 3 & 4 is views of the side of the front seat to see whether or not there is a tag on the seat side about side air bags. So with this info & going by the link below :
    http://priuschat.com/forums/knowled...andard-optional-equipment-most-countries.html
    I'm guessing your car is a GY (Pkg 1) if it has the side airbags in the front seats or a base unit (Pkg 0) if it doesn't. I hope this helps you some.
    Ken (in Bolton,Ct)
  4. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    dutchtouch,
    I agree with Ken's analysis. If the car has the front seat side airbag tag, then it's Option Package 1. If it doesn't, then it's the Base/Standard Prius for 2006 with no Option Package.
    For your reference, here's a link to the 2006 Prius eBrochure which lists and describes all the standard equipment and Option Packages:
    http://www.toyotacertified.com/ebrochures/06_prius.pdf
    Also, if you want, I have a high quality scan PDF of the 2006 Prius print brochure. Send me an email at [email protected] and I'll email it to you.
    Good luck.
  5. thedutchtouch
    181
    Baltimore MD
    thanks guys! i'm in the market for a prius so was trying to fins out if this one was a good buy with ~52k miles at $16,900, i think i'll wait for another.
  6. Boo
    5,051
    488
    97
    Flushing, NY
    dutchtouch,
    Good luck on your search. If it's any help, here are the links to the Toyota Certified Used Vehicles page, and to each model year's eBrochure:
  7. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    the low res screen is a dead giveaway that it is either a base or package 1
  8. dogfriend
    7,512
    1,188
    Carmichael, CA
    Another clue is that it does not have the JBL logo on the audio system - it has the base single CD system.
  9. jelloslug
    jelloslug It buffed right out!
    813
    Greenville, SC
    There are no black smart key buttons on the doors so it's a base model or a package 1
  10. rigormortis
    1,340
    26
    san jose, ca
    once you see a prius of 2006?? or later??? and it has the low res screen you do not have to start looking for anything else. heh
    now if it had fog lights and a low res screen, it would be either a touring.... or a bad repair job or a mod
