Is this what I want to see in used car history: "Fuel injection system flushed/serviced"?
Discussion in 'Prius v Main Forum' started by PriusPaddler, Oct 18, 2024.
  1. PriusPaddler
    PriusPaddler Member
    195
    45
    Twin Cities, MN
    So, still in search of used v. Reading carfax reports, learning about gen 3 engine issues. Still pretty ignorant. I am a DIY person around the house, but not engine-savvy.
    So - when I read a carfax report and it says "Fuel injection system flushed/serviced" I assume that is a GOOD thing toward heading off the typical gen 3 catastrophic failures? Or have I got it all wrong?
    If a car has that at say 50k and again at 80k, with no actual repairs listed, is that at decent intervals? Then (same owner) nothing more and now car is at 150k... does that mean they were addressing a problem or that they changed their maintenance strategy?
    I know - overthinking it all. I either need to jump in and deal with the fallout, or jump out.
    Thanks for putting up with me.
    50,800
    yeah, that won't do anything. but it might help with the fuel system. it's a dealer scam, and most don't do it or wait until there are obvious problems.
    maybe they came here and asked, after getting soaked twice by the dealer. :cool:
    PriusPaddler likes this.
  3. Leadfoot J. McCoalroller
    7,757
    7,227
    Pennsylvania
    2018 Prius c
    Most fuel system cleanings are a ripoff.
    So, it mostly means the previous owner wasn't really a car person either.
    PriusPaddler and Mendel Leisk like this.
  4. ColoradoBoo
    ColoradoBoo Senior Member
    1,110
    727
    Monument, Colorado USA
    Yep, it's an unnecessary expense as long as the owner uses Top Tier fuel but how are you going to know if they did? But even if they didn't probably running some bottles of gas additives that cleans fuel injectors wouldn't be a bad idea.
    My main concern would be the oil changes and coolant changes history of any used vehicle.
  5. rjparker
    rjparker Tu Humilde Sirviente
    9,285
    5,656
    Texas Hill Country
    Does not help but lightens your wallet.
    5k mile oil changes from the beginning, 50k or sooner engine coolant changes, avoid long idle periods, avoid high speed (>70mph) driving, don’t tow - all might help.
    If it burns oil, start considering where you can get a rebuilt engine when it blows. Its better to be prepared than junk it suddenly.
    Toyota Europe says avoid long idles, excessive stop and go, and high speed high load situations. No mention of egrs.
    Toyota has revised intakes, egr valves and ecu logic available. Some of us have updated these.
    Carfax reports often are incomplete and are primarily useful for checking mileage, another issue as the odos* are easily rolled back. Big engine issues or wrecks handled by independent shops or diy are usually missing from Carfax. A scammer can also temporarily hide a blown head gasket with a $20 can of sealer.
    The best advice for a guy who has not bought one yet is to buy something else that any shop can fix with parts from the local auto supply. The perceived mpg advantage of a used gen3 Prius is not worth it.
    *Odometer Rollbacks
    https://www.capitalone.com/cars/learn/finding-the-right-car/how-to-look-out-for-odometer-rollback-when-buying-used-cars/1545
    #5 rjparker, Oct 18, 2024
  6. Mendel Leisk
    40,230
    I wouldn’t touch a Gen 3 or v with over 100k. If it’s for sale there’s a good chance of one or more of:
    failed head gasket
    Runaway oil consumption
    Brake booster failure
    Hybrid battery failure
    PriusPaddler and V Sport Wagon like this.
  7. Prodigyplace
    12,361
    11,660
    Central Virginia
    When my son traded in his 2015 Prius v, it had none of those issues, to our knowledge. He had the car since new and put on a lot of miles traveling to dog shows & dog agility events. He chose a RAV4 Prime ad a replacement and an upgrade to allow an EV only work commute.
  8. PriusPaddler
    PriusPaddler Member
    195
    45
    Twin Cities, MN
    Hilarious and probably true. Good to know, thanks.
  9. Mendel Leisk
    40,230
    It's good to periodically pull off the throttle body (you can leave coolant hoses attached) and wipe down the passage and plate with carb cleaner.I wouldn't pay $100's for this though; it's about a half-hour job, about half the time pulling off the air box. The clamp that secures the duct to top of throttle body is a pain: you have to squeeze it (offset needle-nose pliers with long reach work good) just right, to expand AND lock it. Hard to explain, easier to figure out by doing it. Torque values for the hold-down nuts/bolts on throttle body in attached. Note, those values are in inch pounds.
    The fuel injector cleaner seems pure BS; they're constantly being cleaned by gasoline.
  10. V Sport Wagon
    V Sport Wagon Active Member
    375
    131
    Southern California
    The dealer "version" of the service yes. And no, there's a ton of carbon deposits on the tips of the injectors as the car racks up miles without having them pulled and cleaned. It does affect the spray pattern and holes.
  11. Mendel Leisk
    40,230
    I suppose if you've got the intake manifold off, just wiping them with carb cleaner on a rag is as effective, at least for cleaning the tips? Maybe more so.
  12. Air_Boss
    Air_Boss Senior Member
    4,124
    1,146
    New Yawk
    Full wallet flush…
  13. V Sport Wagon
    375
    131
    Southern California
    They need to be put on the injector tester and flow machine to do it correctly. You will never know by just "wiping the tips off" with cleaner how much each injector may be flowing. It makes a huge difference in how the car runs and MPG.
  14. bisco
    50,800
    is it in the toyota maintenance schedule? most cars go many, many miles before needing injector cleaning, if ever.
  15. rjparker
    9,285
    5,656
    Texas Hill Country
    The number one purpose of additives in all gasoline is to keep the injectors clean. As a result there is no required maintenance. Marketing for profits at dealers and some franchise shops sells aftermarket procedures.
  16. V Sport Wagon
    375
    131
    Southern California
    Is the EGR cleaning service there? No? Well then...I'm also not talking about dumping a solution in the gas tank and letting it run through your engine like the dealerships do either obviously. After having done hundreds of sets through a bench flow tester/cleaner, we have it down pat. The main benefit is better mpg +2-3..not claiming much else, just the proven results.
  17. bisco
    50,800
    how can fuel economy go up, if it hasn't gone down?
  18. V Sport Wagon
    375
    131
    Southern California
    It will slowly go down over time due to many factors, this simply helps bump it up a couple as the injectors get more and more clogged over time. I know Prius Chatters have a hard time with actual science, but try..
  19. bisco
    50,800
    mpg don't normally go down at 50 and 80k.
    science is great, you haven't presented any
    #19 bisco, Oct 21, 2024
  20. Mendel Leisk
    40,230
    When dealerships offer services beyond Toyota's recommendations, I suspect the main criteria are max profit and min effort. EGR cleanout does not meet the criteria; the only thing they'll volounteer (if you press them) is parts replacement, at full retail cost for parts, and likely half at least half a day's labour. Because it it doesn't meet their criteria. And then of course: Toyota would love for all the EGR issues to just "go away".
    You're a professional? Independent shop?
