Just an idle thought.....
Discussion in 'Gen 2 Prius Main Forum' started by max-greece, Sep 21, 2011.
  1. max-greece
    max-greece New Member
    Greece
    The Prius re-captures energy normally lost to the brakes. Could something similar not be done with the suspension? I'm thinking of some kind of electronic shock-absorber. I'd imagine that even on the smoothest roads that thing is moving in a repetitive, predictable way up and down - ideal for a small electric generator.
    Better yet - it would have its maximum effect on long distance routes where the benefits of the Prius are not as high as they are in urban environments.
    What think we? Great idea or impossible for a whole host of technical reasons I have missed?
  2. Paul58
    Paul58 Mileage Miser
    1,126
    125
    Atlanta
    Sounds perfectly logical to me! Couple this with small wind turbines behind the grill and a larger solar panel on the roof and I'd think the Prius would be a lot closer to being self suffecient! Not quite to the point of self sustaining, but close. The ability to recharge the battery without the use of the engine would have a tremendous effect on fuel effeciency!
  3. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Not impossible, just impractical. Where the amount of available energy is small the extra cost, and worse still extra weight, is just not worth it.
    For example if the extra apparatus needed for the suspension weighed just 2kg, it would probably add about 10 Watts extra average power to run the car (based on every 1% increase weight adding about 1/2 a percent of extra power usage). Now if this device made say 5 Watts extra power then it wouldn't exactly be money well spent!
    Interestingly an old motor bike collector once told me that there was one vintage motorcycle (early 1900's) that used the up/down motion of the suspension to power the fuel pump. Apparently as roads and highways improved over time that these bikes stopped working properly, with riders having to stand and bounce up and down periodically just to keep it running.
    Something more practical and quite likely to soon appear on at least some production cars is a thermoelectric generator. These are semiconductor devices (no moving parts) that can extract electrical power directly from the waste heat of the exhaust system. BMW and VW are both actively researching these and I think they're up to several hundred watts of power. Not quite enough to replace the alternator on a conventional car but getting somewhere in the ball park.
    2 people like this.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    It's more likely that this will happen if cars eventually use some sort of electronically damped suspension. If the components are there already it makes sense to capture the wasted energy, just as regenerative braking uses the electric motors already in the car. Otherwise the weight and cost are prohibitive.
    Tom
  5. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
  6. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    I have a flashlight that works on the same principal. It was given to me by, of course, Toyota.
  7. Paul58
    1,126
    125
    Atlanta
    How about a turbine that's powered by exhaust? Like a turbo, but instead of the exhaust powering the turbine that forces air into the intake, it powers an electric generator?
  8. a_gray_prius
    2,927
    783
    IL
  9. fotomoto
    fotomoto Senior Member
    5,626
    3,802
    So. Texas
  10. max-greece
    Greece
    Rokeby,
    You just made my day. I actually had an idea that's feasible. Course someone else thought of it first but most of my ideas end up looking like the Direct Exhaust Injection system above.
  11. ahmeow
    ahmeow Prius Lover
    366
    70
    North CA
    You guys are all genius. I admired.
  12. max-greece
    Greece
    ahmeow.
    Good choice on the colour of your Prius. Mine's black too.
  13. SpikeVFR
    SpikeVFR New Member
    221
    SF Bay area, CA
    could it be done, sure. Absolutedly, the actual product doesn't exist yet, but the technology certainly does. Heck, I remember seeing a pair of shoes that were made to generate electricity with every heel strike. The problem is the cost/benefit equation. The cost of such a system, would outstrip the electricity generated for now. Especially on a hybrid, which always has the ICE. On a full electric, it could make a little more sense, since more electric juice without more batteries is always good. But still, as of now, the cost of such a system would outweigh the benefits. It is the same thing as the idea of putting solar panels on the roof to charge the battery. It can be done, the technology is there already; but the cost of the implementation is pretty high and the actual power produced is pretty low. So we don't see it yet. Now the Fisker Karma is supposed to get solar panels on the roof, but that is not really in the same price range as the Prius.
