Just bought (New 2 me) 2001 Prius, 142k
Discussion in 'Generation 1 Prius Discussion' started by timtim2008, Jul 23, 2009.
  1. timtim2008
    timtim2008 Member
    204
    22
    Alpharetta, GA
    Just bought (New 2 me) 2001 Prius, 139k
    Found a good deal on ebay, and picked it up this weekend..
    So far so good..
    So far put about 500 miles on it, and i've been between 42mpg and 51mpg.. (i snaped the picture above, when i was on the highway stuck in traffic.. weeeee)
    Wish me luck guys..
    I'm going to change the transmission fluid, air filters, and coolant this weekend..
    anything else i should do?
    Anything i should look out for?
  2. Patrick Wong
    18,200
    6,490
    Congratulations on your purchase. The mpg looks good, your drivetrain must be operating pretty well.
    While you are doing the maintenance I suggest you consider the following unless you have service history showing the items are current:
    1. Replace iridium spark plugs every 60K miles, using the correct NGK or Denso plugs
    2. Replace engine oil and oil filter, using 5W-30 weight
    3. Replace brake fluid; however if you plan to DIY make sure you don't let any air into the system upstream of the wheel cylinders. If air gets in it will be almost impossible for you to get the air out without having the correct Toyota diagnostic tool.
    4. Check the struts/shocks and replace if needed
    5. Check tire condition and replace as needed
    6. Inspect throttle body interior and throttle plate and clean if you see black deposits
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,000
    Fort Lee, NJ
    I thought Iridum spark plugs last 120k miles.
  4. Patrick Wong
    18,200
    6,490
    This is true for 2G.
    The Classic service interval is 60K miles. Some Classic owners have had DTC P3191 "engine does not start" especially if their vehicle does not have the latest revision engine ECU. In that case fresh spark plugs might help.
  5. jdms2000
    jdms2000 New Member
    37
    Irvine
    2002 Prius
    fresh transmission fluid? i'd also pull the transaxle pan and wipe it clean
  6. bwilson4web
    15,933
    I would recommend cleaning the throttle plate.
    You might also consider visiting the Yahoo Groups that deal with the Prius because their message logs have a lot of 'lessons learned' about the NHW11, 2001-03 Prius. I'm fond of "toyota-prius" and "Prius_Techincal_Stuff," which started from the earliest days of the Prius.
  7. bwilson4web
    15,933
    It comes from early oil testing and isn't that hard to do. I've tried to assemble some stuff over time.
  8. timtim2008
    timtim2008 Member
    204
    22
    Alpharetta, GA
    ok, i loved the car soo much i just got a Genii... damn.. now i have 2 prius's. what to do? lol
  9. tochatihu
    tochatihu Senior Member
    9,457
    3,655
    Kunming Yunnan China
    2001 Prius
    Three suggestions not mentioned above. Sorry I arrived late to the party.
    Learn how you quickly assess the correct function of the electricals coolant loop pump. Posted at PC and elsewhere.
    Open up the 12 volt battery compartment in trunk. Make sure the connections are tight and free of corrosion.
    Increase tire inflation to what the tire sidewall says in front; 2 psi less in rear. If this feels harsh to you on the road, decrease in small increments until comfy.
    I don't agree with Patrick about immediately changing the brake flouid. Get it tested at a brake shop for water or copper content. They have test strips. However, if the fluid in the reservoir looks other than the original 'light straw' color, it needs changing for sure.
