Just rescued a 2005 Prius from a repo yard.
Discussion in 'Newbie Forum' started by Beachbummm, Sep 12, 2013.
  1. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    wish me luck its been sitting over a year...
    got her running and moving but red triangle of death is one, I know I will have to change a cell or two.
    the smart key battery leaked inside but got that working again with some cleaning, shocked it held its programing all that time.
    can someone tell me the best way to prep the fiberglass part across the window on the hatchback for paint.
    thanks! :cool:
  2. Beachbummm
    1,160
    392
    forgot to ask, I see theres a recall on the water pump in the charging system, does the code have to be stored in the computer or will the fix them all for free even without the codes...thanks again :cool:
  3. alekska
    alekska Active Member
    435
    138
    Atl
    Broken pump does not necessary results in code (if system did not overheat)....the recall will be done in any case, even without codes.
    - Alex
  4. Beachbummm
    1,160
    392
    thanks, once I get the battery fixed up Im going to take it to the local dealer..I heard if there was no code they had the option to refuse to fix it but I will call before I drive the 30 miles.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,832
    Clearwater, Florida
    You'll have better results when inquiring about repairs if you post them in the Gen 2 Maintenance section.
    Not sure what you mean by fiberglass part? Do you mean the spoiler?
