K & n oil filters
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by dbgfreeusa, Aug 20, 2010.
  1. dbgfreeusa
    dbgfreeusa New Member
    I APOLOGIZE if there is a post that covers this subject. I've searched the forums and have not seen one yet.
    Does anyone have info regarding pros and cons of using K & N Oil-Treated Air Filters in a Prius?
    I've used them in two Chevy V-8 vehicles in the past. I still own a Hot Rod / Show Car that has a K & N Air Filter.
    When I was surfing the internet for pricing on Air-, Cabin Air- & Oil-Filters for my '08 Prius I found them listed on at least 2 or 3 Online Parts Dealer's sites.
    Any feedback would be appreciated. My '08 will be 3 years young Sept., 2010, at about the same time it reaches 34,000 miles, with no interest in parting with it.
    K & N Filters run a little more but over time they are less expensive than replacing paper filters plus they trap most every bit of lint, dust or dirt that tries to get to the engine by way of the intake system.
    Feedback Please!
    Thanks,
    DBG
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    It has been debated on several other threads. There are two principal disadvantages with K&N filters for the Prius:
    1) They let in more dirt.
    2) It is fairly easy to get oil on the mass flow sensor.
    I wouldn't use one.
    Tom
  3. dbgfreeusa
    Thanks for the reply. I definitely don't want to take a chance fouling up that sensor. I'll be happy staying with the OEM filters. I am wondering though...how or why would dirt make it past the K&N Filter.
    --David
  4. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Hold one up to the light, you can see the holes in it.:eek: The fact that they pass more dirt than a paper element has been well documented, not that it needed to be.:eek:
    If K&Ns were any good you would see them as standard equipment on multi k$ expensive commercial and military off road equipment. you won't because those people know better.
  5. finman
    finman Senior Member
    1,287
    111
    Albany, OR
    2014 Nissan LEAF
    That's FUD and BS. I've been using a K&N air filter for the last 4 vehicles:
    old Jeep CJ5, 10 years over 160,000 miles;
    newer Nissan Pathfinder, 70,000 miles;
    and currently 2 Prii (his and hers!)...2004 and 2005, both with 85,000 miles. EVERY vehicle has had no problems with air intake, mass airflow sensors, or "letting in more dirt". my 2 cents, your mileage may vary. And none of these vehicles have I had to throw away a filter. wash and re-oil.
  6. Patrick Wong
    18,200
    6,490
    The issue with MAF sensor fouling is possible with Classic Prius, where the air filter is immediately above the area where the MAF sensor is located. I've seen a few posters who have reported that specific issue.
    I would say this problem is less likely with 2G, since the air filter is located to the side.
    However, the idea of an oil-soaked air filter goes back to the 1950's, and I personally do not see the value of such an idea, having to remove and clean the filter periodically, etc. I don't mind paying $13 for the correct air filter and replacing it after it collects sufficient dirt.
  7. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    I think they might be a good filter for an 30 year old car that needs to breath as much as possable to get the extra hp. I think it would be a waste and i'm willing to bet Toyota would not warranty a ICE repair if they saw a K&N filter in the car, Such as excissive oil consumption, or anything of that nature.
  8. qbee42
    18,058
    3,076
    Northern Michigan
    This is an excellent point. One of the main reasons for using a K&N filter is to improve breathing for more power. This makes sense for racers and heavy equipment, but not for a Prius in ordinary use. Prius engines are lightly used; ultimate horsepower is seldom an issue.
    Tom
  9. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Hi Tom, you won't see them on well maintained heavy equipment either. Those engines can cost many times the price of a Prius engine and are expected to last several times as long as a Prius engine. The owners want the best filtration they can get.
    There is also usually more restriction in the airbox and intake ducting than there is in the air cleaner element so drop in replacement K&N elements usually don't show enough gain to be reliably measured on a dyno.
  10. adamace1
    1,403
    193
    Charlotte, NC
    Yep i work for a highway construction company, we would never use K&N in our equipment. Not when it costs, 20-75k to rebuild a motor.
    2 people like this.
  11. edthefox5
    edthefox5 Senior Member
    10,096
    4,829
    Clearwater, Florida
    I assume you mean the cone CAI's and not the drop in's?
    I tried installing a cone CAI filter on my 07 when I first bought it as I had 2 left over from other cars. I got one installed real good and the car ran really really bad. It would just bog if you gave it the gas. If you very slowly accelerated it would be ok though. I assume the maf sensor did not like it. Really big difference in the way the engine felt with a cone on it and not in a good way.
    You could hear it too inside the cabin. That little 4 banger sucks some really good air!
    It didn't throw a cel though.
  12. Mr.Vanvandenburg
    1,311
    534
    2020 Prius Prime
    I believe this is the reason for turbocharging, force more air in for more power, assuming the fuel injection/cylinder head is up to it. But the AF doesn't do that, it sits and does nothing. It isn't the most restrictive element in the system, it isn't a race car. I have never floored my Prius in the three+ years had it. There are plenty of engines out there running no AF at all. and have "no problems." The question is what is better, right? Might search specialist sites like bitog for consensus on K&N. I like the three layer Toyota Denso filter. Seems a safe bet to me.:) to all.
  13. joe350gt
    joe350gt It's too windy here...
    40
    38
    Wichita, Ks.
    DBG,
    I put in a K&N air filter (drop in replacement style, not a CAI) in my '06 at around 60K and I turned 200K last night. I have a K&N on my hot rod too and have never had any issues related to dirt passing thru easier than a paper filter. No noticeable change in power or fuel economy with it. And I've floored my Prius' gas pedal many, many, many times BTW!! It only red lines at 5000 rpm and no ill effects noted so far. So pick your poison and keep up with the intervals to change/clean whatever you have and it'll be ok!!
    Joe
