Lack of acceleration power after 5000 mile complimentary service
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by sa177, May 18, 2012.
  1. sa177
    sa177 Junior Member
    76
    NorCal
    I had the car serviced on 5/13/12 for the complimentary 5000 mile service and after I received the car, I noticed that the car drove a lot slower than before I dropped it off. I thought it was just the tire rotation that might be causing the slow driving, but while driving the car on the freeway and on city streets this week, I had to basically press on the gas pedal all the way down to get the car moving at a decent speed and even then it was extremely slow. I can barely get it to go past 70 MPH. Where as before I had it serviced, it wasn't hard to get it past 70 MPH. Even on city streets, I have to floor the gas pedal to get it to speed up. I purchased the car 3 months ago and I would assume a new car should not have performance issues this early. I'm wondering if the mechanic forgot to tighten something or what? :confused:
  2. JamesCSmith
    JamesCSmith New Member
    59
    It sounds like you are in ECO mode. Tap the ECO button (to the right of the shifter) to toggle it off and go into normal mode or tap the PWR button if you really want a responsive throttle.
  3. macman408
    macman408 Electron Guidance Counselor
    1,179
    367
    What mode was it in before, and what mode is it in now? (Eco, Normal, Power...) Those change the accelerator mapping, meaning you press harder to get the same amount of power. However, flooring it in all three will give you the same thing - maximum acceleration.
  4. sa177
    sa177 Junior Member
    76
    NorCal
    I have always been driving in ECO mode and it never had this hard of a time reaching an acceptable speed, but after the service change, it is still having a hard time reaching a comfortable speed. Even in PWR mode, it has to be floored or in the red zone of the gauge to speed up. So I have no idea what is happening. I'm bringing the car back into the dealership service department for a followup on Saturday. I hope they figure it out and fix it.
    I've also noticed that I use to be able to coast down hills with a lot of speed while gliding, but now it lags like crazy and doesn't reach those fast speeds.
  5. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
    You know if they added 4 quarts of oil, but forgot to drain the oil first, it would act a lot like that, you may wish to check the dip stick.
  6. sa177
    sa177 Junior Member
    76
    NorCal
    Jimbo, I'll check the oil in the morning. Thanks for the suggestion.
  7. Erikon
    Erikon Active Member
    819
    105
    Rochester, NY
    Can it even hold 8 quarts? In any case, they may have overfilled to a degree, or used 10w 30. Dealers are notorious for that!
  8. sa177
    sa177 Junior Member
    76
    NorCal
    At the 5000 miles complimentary service, they didn't do an oil change, but they might have topped off the oil and other fluids, rotated my tires, and performed some minor inspections. I hope it is just that, but I can't believe that extra oil can affect engine performance by this degree.
  9. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Could it be the parking brake is on?
  10. sa177
    sa177 Junior Member
    76
    NorCal
    stream, LOL, i wish that was the case, but I'm positive it's not the parking break.
  11. sa177
    sa177 Junior Member
    76
    NorCal
    The engine oil is right at the high mark on the dip stick.
  12. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
    Darn, as you can see, we are trying to guess from a distance and may be off base, but we are on your side!
  13. sa177
    sa177 Junior Member
    76
    NorCal
    I'm extremely appreciative of PriusChat and all of it's members. All the knowledge I have gained from this site is extremely helpful! I just hope I can figure out what is wrong w/ the car. I never had to push the car this much before to get it to speed.
  14. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    What are you seeing for the HV battery SOC?
    Tom
  15. sa177
    sa177 Junior Member
    76
    NorCal
    what is the HV Battery SOC?
  16. stream
    2,977
    452
    Long Island, NY
    Just thought I'd throw it out there.
  17. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    The HOV battery state of charge would be the battery Icon on you HSI screen (6 bars is normal). Or if you have a scangauge, you can program it to read your SOC (in percent).
  18. Codyroo
    1,826
    515
    Pleasanton, Ca
    Is the car decelerating more quickly than normal as well? Have your MPG's been impacted? If you cruise 60 mph on a flat road (with no significant wind) what MPG's are you seeing? I wonder if somehow a brake isn't letting go fully (emergency or otherwise)
  19. billnchristy
    billnchristy Active Member
    924
    123
    GA
    2016 Chevy Volt
    Tire pressure?
  20. sa177
    sa177 Junior Member
    76
    NorCal
    The HV Battery SOC is average (usually above the midline). Yesterday, it was about 85 degrees and when I started the car, the HV Battery SOC had only 2-3 bars (below the midline).
