lag time between systems when starting Prius
Discussion in 'Gen 2 Prius Main Forum' started by lizmariecat, Feb 11, 2011.
  1. lizmariecat
    lizmariecat New Member
    AZ
    :( Hi. I'm seating in my 2008 Prius (new to me and at about 45k miles) and when I have foot on brake and push starter button my screen lights up, dash indicators etc, but there is a very long lag time (or so it seems) betwwen my silent start and when gas engine kicks. The car will not go into anything other than neytral until the second engine kicks in....and there I sit. It does comes on but it's a good 30-60 seconds....a little weird? Anybody have an experience like this? Thanks!
    50,801
    never. i have 'ready' in less than a second. what do you mean by second engine kicks in?
  3. lizmariecat
    AZ
    now you see why I'm a junior member...ha ha. Well first everything is totally silent and dash lights on but 'ready' doesn't display right away...and there is that lag time until I hear a motor (maybe not a second motor--sorry;).
    50,801
    how long have you had it, has something changed?
  5. lizmariecat
    AZ
    about 6 weeks--always a bit of a lag time, does seem a little more lately. Guess a dealer visit in my near future,eh?
  6. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    I am not sure what you are even describing...
    Car is OFF. No lights, nothing.
    Press the brake pedal.
    Press the Start button.
    Hear 1 click - current limiting startup relay for the HV battery
    Hear 2nd click - regular HV relay (1st relay also disconnects with a click but very shortly afterwards)
    Car is now READY.
    Shift into D/R.
    No matter what "gear" you are in (P/R/D/B ), the gas engine (ICE) will start at most 7 seconds after READY. However, the car is fully drivable before this. If your battery charge is low, the engine will kick on sooner. Same with if the HVAC settings require it.
    If this is not happening, then take a video of the start sequence and post it.
  7. bisco
    50,801
    it could be that you don't understand how a hybrid works. however, when you put your foot on the brake and press power, the ready light should come on within a few seconds and you should be able to shift into drive and go, regardless of when the engine kicks on. the engine is independent of the drive system in terms of whether it is running or not. if you cannot shift into drive until much longer than a few seconds, a trip to the dealer is just what the car doctor ordered. all the best!
  8. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    You don't need to wait for the engine to start. After power up, there is about a two-second wait for the car to be "Ready", at which point you can shift into D or R and drive away. The engine will turn on later when it needs to.
    Tom
  9. lextoy
    lextoy Active Member
    291
    131
    philadelphia
    2018 Prius Prime
    make sure you are not stabbing the start button too quickly,
    press it and hold it for 1 second.
    if you stab it too quick it can confuse the car.
  10. uart
    uart Senior Member
    4,220
    1,209
    Australia
    As mentioned above try holding your foot on the brake (firmly) and holding the start button for one second (or even 1/2 a second is ok but don't just "stab" it).. Then keep your foot on the brake and wait 2 to 3 seconds before you try to put it into "D" (or "R" as the case may be). It should go straight in, but do wait for that couple of seconds until you hear the "ready" beep before you try to shift into gear and keep your foot on the brake.
  11. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    wow.. a true newbie.. how exciting
    as people have mentioned.. and ill repeat just to beat this dead horse (where did that icon go anyway...) (i'll skip it... don't care to reach for the mouse...)
    driving a prius 101:
    jump in.. press break.. press start button.
    dash says "ready"
    u: Go
    Prius: starts out on electricity
    u: where's the gas engine.. did i break it?...
    Prius: decided a warm-up cycle is needed, and starts up the Internal Combustion Engine.. or ICE for short... (motor refers to the electric motors)
    u: this prius engine finally kicked on (u should be driving at this point)
    Prius: reduces load on the ICE so it can warm up without any real pressure or load on it... runs ICE a little higher to keep electric feedback high... or to keep battery State of Charge or SOC for short topped off (which is only really ~%80) (it will drop... should drop every warmup cycle.. will go back up too)
    u: stopping at the nearest stop light.. over 30 seconds away or so.. and over 10 mph or so in speed to get there. (i've seen different data on this)
    Prius: gas engine warmed, check. speed achieved, check. break pedal fully depressed at this stop light or sign, check... i'll switch the ICE out of warmup cycle, and shut it off. i'll also re instate the ICE's carrying load and work on filling the battery back up to 6 bars.
    u: depending on if you're sitting in the garage still:
    about time this thing works
    or
    cool, the warmup cycle is done, and i NEVER have to sit around and wait for it since my car is better than that...
    one of the joys of owning this car is the joy of walking to your car the same time as everyone else.. but jumping in your car and driving off instantly without causing damage as it's designed to handle itself and it's warmup, charge, cooling, and any other cycle you can possibly think of. the rest of this car is just as smart..
    it's smarter and stronger than you think... i've tested it.. it way too many ways (specially durability of the drivetrain and chassis)
  12. bisco
    50,801
    where you at, lizmariecat? did u go 2 the dealer? how are you making out?
  13. richard schumacher
    7,664
    1,042
    United States
    Wait, what? You mean it takes 30-60 seconds before the "READY" light comes on? If so then that requires a trip to a dealer, because something is wrong.
    As soon as the READY light is on you can drive. You do not have to wait for the engine to start.
    If you do not have a copy of the Owner's Manual for the correct year then buy a copy from a dealer. It's full of info that you need to know.
