Laser Jet 8000N FS
Discussion in 'Private Sales' started by parrot_lady, Jan 15, 2008.
  1. parrot_lady
    parrot_lady Member
    350
    Chicago Burbs
    Located near Columbus Ohio. Can deliver between here and Chicago,IL.
    WILL NOT SHIP-- weighs 99lbs and would cost a mint!
    Has printed ~139,000 pages (approx one month's duty cycle on it). I have two and don't have a need for the second any more. Both are great machines, I clean them semi regularly with canned air, and can be networked. Specs below:
    [FONT=verdana, arial, helvetica]Monochrome Laser[/FONT][FONT=verdana, arial, helvetica]P[/FONT]
    [FONT=verdana, arial, helvetica]24 PPM[/FONT]
    [FONT=verdana, arial, helvetica]17 Seconds first page out[/FONT]
    [FONT=verdana, arial, helvetica]1200 x 1200 DPI[/FONT]
    [FONT=verdana, arial, helvetica]Optional via JetDirect Internal or External Print Servers[/FONT][FONT=verdana, arial, helvetica]C[/FONT]
    [FONT=verdana, arial, helvetica]y[/FONT][FONT=verdana, arial, helvetica]IEEE 1284 Bidirectional Parallel[/FONT]
    [FONT=verdana, arial, helvetica]3 Open EIO Slots[/FONT]
    [FONT=verdana, arial, helvetica]Memory: 16 MB (expandable to 192 M[/FONT]
    [FONT=verdana, arial, helvetica]Printer has 1 internal fixed in memory of 8 MB and 4 Open Slots of which one is occupied with a removable 8 MB Module [/FONT]
    [FONT=verdana, arial, helvetica]Processor:[/FONT][FONT=verdana, arial, helvetica]133 Mhz[/FONT]
    [FONT=verdana, arial, helvetica]Optional 2 GB Hard Drive (C2985) [/FONT]
    [FONT=verdana, arial, helvetica]Paper handling:[/FONT][FONT=verdana, arial, helvetica]Input: 1,100 Sheets (Max Input is 3,100 sheets)[/FONT]
    [FONT=verdana, arial, helvetica]Input Sources: (1) 100 Sheet Side Flip Tray, (2) 500 Sheet Bottom Tray[/FONT]
    [FONT=verdana, arial, helvetica]Output: 600 Sheets[/FONT]
    [FONT=verdana, arial, helvetica]Output Sources: Top Output Bin [/FONT]
    [FONT=verdana, arial, helvetica]Paper Handling Options:[/FONT]
    [FONT=verdana, arial, helvetica]~Duplex Unit (C4782A)[/FONT]
    [FONT=verdana, arial, helvetica]~2000 Sheet input tray (C4781A)[/FONT]
    [FONT=verdana, arial, helvetica]~2 x 500 sheet multiple input tray (C4780A)[/FONT]
    [FONT=verdana, arial, helvetica]~3000 sheet stacker (C4779A)[/FONT]
    [FONT=verdana, arial, helvetica]~3000 sheet stapler/stacker (C4788A)[/FONT]
    [FONT=verdana, arial, helvetica]~Staples for 300 sheet stapler stacker (C4791A)[/FONT]
    [FONT=verdana, arial, helvetica]~7 Bin Tabletop mailbox (C4783A)[/FONT]
    [FONT=verdana, arial, helvetica]~8 Bin mailbox (C4785A)[/FONT]
    [FONT=verdana, arial, helvetica]~5 bin mailbox with stapler (C4787A)[/FONT]
    [FONT=verdana, arial, helvetica]~Staples for 5 bin mailbox with stapler[/FONT]
    [FONT=verdana, arial, helvetica]~100 sheet envelope feeder (C3765[/FONT]
    [FONT=verdana, arial, helvetica]Paper Sizes: letter, legal, executive, tabloid, monarch envelopes, Custom: 3.9" x 7.5" to 11.7" x 17.7"[/FONT]
    [FONT=verdana, arial, helvetica]Max Paper Size: 11.7" x 17.7"[/FONT]
    [FONT=verdana, arial, helvetica]Print Area: Unknown[/FONT]
    [FONT=verdana, arial, helvetica]Media Types: Paper (copier, bond, special application, recycled), transparencies [/FONT]
    [FONT=verdana, arial, helvetica]Duplex: Optional [/FONT][FONT=verdana, arial, helvetica]Duty Cycle[/FONT][FONT=verdana, arial, helvetica]130,000 Pages Per Month[/FONT][FONT=verdana, arial, helvetica]Dimensions[/FONT][FONT=verdana, arial, helvetica]Unit: 21" x 21" x 21"[/FONT]
    [FONT=verdana, arial, helvetica]As Shipped: 31.5" x 27.6" x 29.0"[/FONT][FONT=verdana, arial, helvetica]Weight[/FONT][FONT=verdana, arial, helvetica]Unit: 99 Lb[/FONT]
    (some paper handling methods mentioned are optional and I don't have them)
    I am unsure about the HD in mine as I was told it is an optional accessory. I can and have bought a duplexer for the one I'm keeping on Ebay. I will include the toner thats left in the cartridge a new cartridge runs anywhere from $25- $100 depending on where you buy it from. Includes the network adapter.
    If I had the space, and need I'd keep it, but sadly I don't have either. Can send pictures if necessary.
    I'm asking $100 delivered(if close to Chicago it will be a Monday or Tuesday as those are my days off)/meeting you somewhere. This is before I try to go to ebay or craigslist (where I will be asking more for it). I figured I'd start here as I've seen other non car items on here.
    The printer will fit either (1) in the back seat of a prius or (2) in the hatch area with the rear seat folded down.
    PM me or email handfed.babies at gmail dot com with 8000N in the title if interested.
