Last mile EV... your thoughts
Discussion in 'Gen 3 Prius Main Forum' started by lamontcranston, Sep 17, 2009.
  1. lamontcranston
    lamontcranston Umbra Tenet
    212
    17
    Southern California
    I know this has been discussed before, and I know what was said. I've had different results, and perhaps I'm just "special."
    The last mile of my commute is all uphill with three stop signs. This also means that the first mile of my commute is all downhill with three stop signs.
    It's been said that using EV for the last mile is actually worse, because the car needs to use extra energy to recharge the battery in the morning when it's least efficient.
    Except, I seem to have better results from using EV for the last 5/8 mile or so (so that the engine stays off all the way into the garage.) In the morning, I get a lot of regen braking and coasting because it's all downhill. So the ICE is on anyway, but MPGs are pretty high (30-40) and the battery is back to 5 bars before I get to level ground.
    Is mine just the exception that proves the rule?
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    I think that's fine, and probaby a logical use of EV. Here's why...you're downhill in the morning, so you don't need to really 'borrow' battery power.
    If you had a Scan Gauge or CAN-View I'd recommend that, in the morning, that you just be careful to keep your RPM below 1300 until S1 is complete and to make sure your amp draw was less than about -15 during that same time...indeed, going downhill, you may be able to have a positive amp read and be charging the battery a bit.
  3. JRitt
    JRitt Bio-Medical Equip. Tech
    133
    St Louis, Mo
    The last 1.1 mi of my drive is slightly up hill in a residential neighborhood (max speed 25mph). I do this in EV to partialy deplete the battery because in the morning I go down the hill that when warm is all battery and low current draw (I lose only 1 bar for the mile+) but when the engine is cold it has to run anyway to war up the cat. converter so I might as well let it charge the battery.
  4. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    I would think that if you have tried it, and it worked, then it worked. I tried it, I live on dead flat ground and it didn't work for me, but I live on dead flat ground.
    Or for every rule there is an exception, I think your case is an exception.
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    Obviously, if your morning downhill contains more energy than your HV battery can take in its nominally charged state, it makes sense to run down the battery a bit on the evening uphill. How much will depend on your exact circumstances. Do a little experimenting and see how much battery you need to take the whole downhill regen. Aim for that as your target SOC at the end of the day.
    Tom
  6. lamontcranston
    212
    17
    Southern California
    That's a good idea. As I said the battery hits 5 bars by the time I get to the bottom of the hill so perhaps I need to use a little less battery on the way home. Great advice!
  7. a64pilot
    771
    62
    Albany Ga.
    Only question I have is I have always been taught that you should not leave a battery discharged. Just wonder if putting it to bed with a low SOC would over a long time shorten the battery life?
    Me, I want to use EV for the last two miles and then charge the battery overnight. I can get two miles merely maintaining speed. It's not much, but it's two miles
  8. MikeDS
    MikeDS Member
    298
    Los Angeles
    My understanding is even when the Prius's SOC looks empty, in reality the battery is still are 40%, or something like that. I remember reading how the Prius never charges all the way to 100% or discharges all the way...part of extending the battery life.
    Plug-in over night would be awesome...kinda thought I was gonna get that when I was buying a Gen III, haha...
