Latest Oil Analysis
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by triumph1, Aug 27, 2010.
  1. triumph1
    triumph1 Member
    275
    Oil Analyzers, Inc.
    '08 Toyota Prius
    Miles on unit- 52k
    Miles on Oil-15k
    Oil-Mobil 1 EP 5w-30
    Filter- Purolator Pure One -Yellow Can
    Make-up oil- .5 Quarts.
    Severity of Report- 1-(Normal)
    Iron-20
    Aluminum-3
    Copper-3
    Silicon-21
    Sodium-6
    Molybdenum-90
    Potassium-1
    Boron-34
    Magnesium-12
    Calcium-2233
    Phosphorous-599
    Zinc-674
    Fuel-<1%
    Soot<.1%
    [email protected]
    Water-.1%
    Oxidation-20
    Nitration-30
    TBN-2.88
  2. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    Good to see your getting a long service interval on a good synthetic. I compared it to my numbers and the only significant difference was that the AMSOIL 0W-30 had a higher TBN number(4.57).
  3. triumph1
    triumph1 Member
    275
    Here's my Amsoil SS0 report-
    Blackstone Labs.
    Miles on unit:17k
    Miles on oil:15k
    Make-up oil: .5 quarts.
    Amsoil SS0, Eao filter.
    You've run this oil for about 88% of this young engine's life, and that's the reason that we are still finding high
    iron, copper, and silicon. We normally expect wear-in to be past by the time you get to about 10,000 miles, but when
    you run long oil changes from the start, the process takes longer. You'll get there eventually, though you could speed
    the process along by changing the oil at 7,500 miles next time. Note fuel at 3.0%. This is more than we like to see but
    hopefully it's from rings seating. The TBN read 4.1 showing some active additive left. Check back.
    ALUMINUM 5
    CHROMIUM 0
    IRON 18
    COPPER 9
    LEAD 1
    TIN 11
    MOLYBDENUM 1
    MANGANESE 1
    NICKEL 1
    SILVER 0
    TITANIUM 0
    POTASSIUM 3
    BORON 5
    SILICON 58
    SODIUM 6
    CALCIUM 3206
    MAGNESIUM 11
    PHOSPHORUS 594
    ZINC 711
    BARIUM 1
    cSt Viscosity @ 100°C 8.85
    SUS Viscosity @ 210°F 55.3
    TBN-4.1
    Flashpoint in °F 315
    Fuel % 3.0
    Antifreeze % 0
    Insolubles 0.3
  4. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Good results
