LED turn signal bulbs w/projector lens
Discussion in 'Gen 3 Prius Accessories and Modifications' started by striker308, Aug 16, 2012.
  1. striker308
    striker308 Three time Prius owner
    302
    43
    Evans, NY (USA) / South Williamsport, PA (USA)
  2. Chunker
    Chunker My name is Chunker...I wear a hat
    71
    Nope but the ship time of 2 weeks kinda sucks...
  3. striker308
    302
    43
    yeah, well they are coming from China where they make then so it's not like I can get them second day.
  4. Steve Type-4
    Steve Type-4 Trading HP for MPG
    174
    102
    SoCal
    I have. In fact, all my small external lights have been replaced with projector LEDs - 7440s, 168s. Only bulbs that are still halogens on my entire Prius is the high beams (Nokya 65 W yellow) and OEM halogen 55 W low beams (to be replaced with 35 W HID soon). Although I might swap out the amber LED on the front parking lights for ion yellow 168 bulbs by PIAA - I liked how they look on my last car.
    LEDs with projector lens greatly amplifies the distribution of the light emitted instead of them just aiming straight forward.
  5. striker308
    302
    43
    So, two arrived ok but the other two didn't work.
    Contacted vendor he is sending two more out no questions asked.
    With only two in (Back only) they are just as bright as the OEM bulb if not brighter. BUT now I have the dreaded hyperflashing.
    anyone know where to get an LED flasher relay so i don't have to install resisters on all four bulbs?
  6. AZGeek
    AZGeek Semi-informed Member
    627
    144
    63
    Arizona
  7. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
  8. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
  9. striker308
    302
    43
    Ordered one on ebay, thanks!
    PITA? where is it?:confused:
  10. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    U need to remove the Blk panel that has the drive side footwell light. Next lay on ur back looking up next to the brake peddle. To the right of the peddle (between the brake peddle & the parking brake) up towards the top of he dash is where the flasher relay is located. If u have the new flasher, u will notice where a tab will go to lock it in place. This tab will need to be released on the original flasher relay & then pushed up to remove it from the holder......helps if u have small hands.
  11. striker308
    302
    43
    Great!
    No small hands, but a bad back and neck.................. this should be fun:eek:
    Thanks for the heads up.
  12. AZGeek
    627
    144
    63
    Arizona
    Yikes. If you are starting out with a bad back and neck then you are probably not going to be a happy camper. You sound like how I wound up after the ordeal. Not having hyper flash is worth the pain. Just keep telling yourself that ( in between explictives!). ;)
    new iPad ?
    striker308 and spiderman like this.
  13. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Ouch.......ur gonna love getting dwn there
  14. SCRWGas5
    SCRWGas5 New Member
    156
    Charlotte, North Carolina
    Ok I need to do this. i want to change my 2012 rear (at least for now) turn signals to LED bulbs. So once I swap the bulbs in, and swap in this relay box thingy I'm good for a nice normal blink for all 4 signals? or is this specifically for the fronts?
  15. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    The flasher relay will work whether ur just changing the back to LED or just the front.
    The only down side to the LED flasher relay is that it will NEVER hyper flash.......meaning that if u have a LED bulb burn out on u u'll never know it without looking
  16. SCRWGas5
    SCRWGas5 New Member
    156
    Does this black panel come off easily? Need tools? Straight pull off? Clips?
  17. SCRWGas5
    SCRWGas5 New Member
    156
    Ok. I got off the black panel. Looking still. No clue where this is going. Anyone got pics??
  18. SCRWGas5
    SCRWGas5 New Member
    156
    Yeh, so I have now spent like 20 mins looking under there. lol. ok maybe not that long. But I lie with my head resting right up against the brake pedal practically and do my best to look up but firstly, how do you even get a clear vision to the top of the dash? I have climate vents and pedal shafts and all kinds of crap in my way. And I have no idea what/where is the relay. I took a few pics of up there to see if maybe someone can point out to me where they see it if they do. The other thing I'm no skeptical about is, once you see this thing way up there wherever, is it really in a place that you have room to work two hands to pry out the old one and place the new one? :confused:
  19. SCRWGas5
    SCRWGas5 New Member
    156
    Does anyone know/see the relay that's to be replaced in any of these pics???:unsure:
  20. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    ^ in the 2010, the relay was planted in that semi-opaque white box above the steering linkage. It had a blue housing. Fun isn't it? :)
    There are a couple of threads that have pictures in them.
