Light upgrades (Fog/ head lamp)
Discussion in 'Gen 3 Prius Accessories and Modifications' started by mohammed khan, Jan 19, 2017.
  1. mohammed khan
    mohammed khan Junior Member
    44
    fiji islands
    hi ,
    need advise and recommendations regarding the upgrading of the prius gen 3 2010 model fog lamps and low beam head lights. I have the factory halogens at the moment but want to upgrade to HID or LED but cant decide which is the best in the long run and in terms of brightness. would appreciate some help.
    thanks
  2. asrab.ali.7
    asrab.ali.7 Junior Member
    33
    Bradford
    Hi iv just recently upgraded the fogs n low beam with hid kit n the high beam with led kit the fogs r ok nice n bright where as the low beam because there is a projector ball don't find it that bright so gona change to led on that
    iPhone ?
  3. asrab.ali.7
    33
    Bradford
    The led is bright 120watt now I have found 160watt so the low beam is coming out very soon
    iPhone ?
  4. mohammed khan
    44
    fiji islands
    hi thanks for your reply can i know the brand and specs of the lights you have installed
  5. asrab.ali.7
    33
    Bradford
    That my friend I can help u with if u go on eBay n tap 160watt h11 shud come up but there r different ones do with the 4 led on each bulb
    iPhone ?
  6. mohammed khan
    44
    fiji islands
    will having high watt and lumen led lights give any problems to the car or wiring or heat up
  7. asrab.ali.7
    33
    Bradford
    No as long as u have installed them properly inshallah u will b fine
    iPhone ?
    mohammed khan likes this.
  8. mohammed khan
    44
    fiji islands
    thanks much appreciated bro . any specific brand you would recommend in terms of quality
  9. asrab.ali.7
    33
    Bradford
    Stark looks good that's wot am gona get for my low beam
    iPhone ?
